Determine the direction of vector
  • Thread starter Thread starter kgianqu2
    Direction Vector
To determine the direction of the vector with components x=7.25 km and y=-3.50 km, the angle is calculated as -25.769 degrees, which indicates a clockwise direction from the +x-axis. However, to express this angle in standard position, it should be converted to a positive angle by subtracting from 360, resulting in 334.231 degrees. The negative y component and positive x component place the vector in the fourth quadrant. A visual sketch can aid in understanding the vector's position. The discussion emphasizes the importance of correctly interpreting angle measurements in physics problems.
kgianqu2
Find the direction of the vector . Let the direction of a vector be the angle that the vector makes with the +x-axis, measured counterclockwise from that axis. x=7.25 km, y=-3.50 km
Please help. I got -25.769, but when I entered it (to the correct sig figs) mastering physics said it was wrong.
Have you tried entering 360 - 25.769 = 334.231?
That worked, thank you so much. But why did it have to be subtracted from 360?
Do they want the answer in degrees?
Yes, but it I got the answer. It had to be subtracted from 360. Thank you anyway.
If the y component is negative and the x component is positive, in what quadrant will it be?
Draw a sketch if you don't see it.
  • · Replies 18 ·
  • · Replies 44 ·
