Determine the perpendicular distance for couple
The discussion focuses on calculating the perpendicular distance between two forces forming a couple, specifically two 50N forces applied at points B and D. The forces are resolved into their horizontal and vertical components, yielding Bx = 38.3N, By = 32.1N, Dx = 38.2N, and Dy = 32.1N. The moment of the couple is calculated as -9120Nmm, leading to a distance of 182.4mm when divided by the force magnitude. The final clarification indicates that the calculated distance of 91.2mm represents half of the total perpendicular distance required.
  • Understanding of force resolution into components
  • Knowledge of calculating moments in mechanics
  • Familiarity with the concept of couples in physics
  • Ability to apply trigonometric functions in force calculations
  • Study the principles of static equilibrium in mechanics
  • Learn about the calculation of moments for various force configurations
  • Explore the concept of couples and their applications in engineering
  • Investigate the use of trigonometric functions in resolving forces
Students in mechanical engineering, physics enthusiasts, and professionals involved in structural analysis or mechanical design will benefit from this discussion.
goldfish9776
two 50N are applied to the corner B and D , determine the moment of couple formed by the two forces by resolving each force into the horizontal and vertical component and adding the two resulting couples . Use the result to determine the perpendicular distance between the line BE and DF
i gt only Bx = 50sin50 = 38.3N (right)
By = 50cos50 = 32.1N ( down)
Dx= 50 sin50 = 38.2 (left)
Dy = 50 cos50 = 32.1N (up)
how to get the perpendicular distance ?
btw , i have used another method which is not relevant to the question asked , whoch is tan 50 = O / 300
O= 357.5mm
hence , perpendicular deistance = 500-357.5mm = 142.5mm
O= 357.5mm
This last calculation does not give the perpendicular distance between the lines of the two forces.
The distance O = 357.5 mm is measured along the edge of the plate, and so is the difference 500 - 357.5 = 142.5 mm.
You must find the distance between the line of each force measured perpendicular to each, similar to what is shown below:
CAN YOU GIVE SOME HINT HOW TO FIND ?
Follow the original directions stated in the problem. Don't go straying off topic.
how to find ? i have only
if i sum up them , i would get 0 .
You're not supposed to sum them up.
Read the problem statement again. Does it tell you to sum these forces up? Or does it ask you to do something else?
well , force the force at B , i have moment = 50sin50(300) -50cos50(500) = -4560N
for the force at D , i also have moment = 50sin50(300) -50cos50(500) = -4560N
so i would get -9120Nmm / 50 = = 182.4mm , am i right ?
You can calculate the stress by axes and the total couple force stress as ##F\times{D}##. Must be equals.
You pick one point and calculate the moments of the force components about that point.
If you choose either B or D as the point about which to calculate the total moment, your calculations are greatly simplified. :wink:
so the ans = 500(32.1)-300(38.3)=4560Nmm
4560Nmm / 50 = 91.2 mm ?
Yes, that is correct.
why not 91.2 x 2 = 184 mm ? this is beacuse when we calculate the sum of couple moment , we will need to consider both side ...
so for the diagram below , the sum of couple moment is F1(d/2 ) +F1(d/2 )
so for the question i asked , the 91.2 mm that we gt is only the d/2 only
Yes, but if you calculate the moments of each force about the midpoint of the distance separating them, then M = F * d/2 + F * d/2 = F * d, since both forces are of equal magnitude.
If F = 500 N and M = 4560 N-mm, what must the distance d be equal to?
the d = 91.2mm , but the d here that we gt is only half of the perpendicular distance of the question i asked originally , right ?
No, it's not. You still have two forces creating the couple, as I showed you in Post #13.
Take the small diagram you have in Post #12 and calculate moments about one end of d (it doesn't matter which end) and again about the center of d. Each moment you calculate should have the same magnitude.
ok , i think i gt your point
9K
11K
29K
  • · Replies 49 ·
