Determine the perpendicular distance for couple
15 replies · 7K views · last reply
goldfish9776
two 50N are applied to the corner B and D , determine the moment of couple formed by the two forces by resolving each force into the horizontal and vertical component and adding the two resulting couples . Use the result to determine the perpendicular distance between the line BE and DF
i gt only Bx = 50sin50 = 38.3N (right)
By = 50cos50 = 32.1N ( down)
Dx= 50 sin50 = 38.2 (left)
Dy = 50 cos50 = 32.1N (up)
how to get the perpendicular distance ?
btw , i have used another method which is not relevant to the question asked , whoch is tan 50 = O / 300
O= 357.5mm
hence , perpendicular deistance = 500-357.5mm = 142.5mm
  • Diagram of a 500 mm by 300 mm rectangle with corners A, B, C and D, showing two parallel 50 N forces at B and D acting at 50 degrees to the sides, in opposite directions.
O= 357.5mm
This last calculation does not give the perpendicular distance between the lines of the two forces.
The distance O = 357.5 mm is measured along the edge of the plate, and so is the difference 500 - 357.5 = 142.5 mm.
You must find the distance between the line of each force measured perpendicular to each, similar to what is shown below:
Diagram of a horizontal plate with two equal and opposite forces F drawn as blue arrows, one at the upper right and one at the lower left, with a red double-headed arrow labelled d marking the perpendicular distance between their lines of action. Labelled Figure 3.
Diagram of a bar with two equal and opposite forces F applied at its ends at an angle, with a red double-headed arrow labelled d marking the perpendicular distance between the two force lines; labelled Figure 3.
CAN YOU GIVE SOME HINT HOW TO FIND ?
Follow the original directions stated in the problem. Don't go straying off topic.
how to find ? i have only
if i sum up them , i would get 0 .
You're not supposed to sum them up.
Read the problem statement again. Does it tell you to sum these forces up? Or does it ask you to do something else?
well , force the force at B , i have moment = 50sin50(300) -50cos50(500) = -4560N
for the force at D , i also have moment = 50sin50(300) -50cos50(500) = -4560N
so i would get -9120Nmm / 50 = = 182.4mm , am i right ?
You can calculate the stress by axes and the total couple force stress as ##F\times{D}##. Must be equals.
You pick one point and calculate the moments of the force components about that point.
If you choose either B or D as the point about which to calculate the total moment, your calculations are greatly simplified. :wink:
so the ans = 500(32.1)-300(38.3)=4560Nmm
4560Nmm / 50 = 91.2 mm ?
Yes, that is correct.
why not 91.2 x 2 = 184 mm ? this is beacuse when we calculate the sum of couple moment , we will need to consider both side ...
so for the diagram below , the sum of couple moment is F1(d/2 ) +F1(d/2 )
so for the question i asked , the 91.2 mm that we gt is only the d/2 only
  • Diagram of a couple: a horizontal red line of length d joins two points, with an upward arrow labelled F1 at the right end and a downward arrow labelled -F1 at the left end, with d marked above the line.
Yes, but if you calculate the moments of each force about the midpoint of the distance separating them, then M = F * d/2 + F * d/2 = F * d, since both forces are of equal magnitude.
If F = 500 N and M = 4560 N-mm, what must the distance d be equal to?
the d = 91.2mm , but the d here that we gt is only half of the perpendicular distance of the question i asked originally , right ?
No, it's not. You still have two forces creating the couple, as I showed you in Post #13.
Take the small diagram you have in Post #12 and calculate moments about one end of d (it doesn't matter which end) and again about the center of d. Each moment you calculate should have the same magnitude.
ok , i think i gt your point
