What Volume of Oxygen Gas is Needed to Combust 3.5 Moles of Propane?
  • Thread starter Thread starter STEMucator
    Oxygen Volume
The volume of oxygen gas required to combust 3.5 moles of propane at standard pressure (100 kPa) and 28.0°C is calculated to be 440 liters. The calculation utilizes the ideal gas law, PV = nRT, and emphasizes the importance of maintaining significant figures throughout the process. The discussion highlights that rounding intermediate results can lead to significant errors, and it is recommended to round only the final answer. Proper application of the mole ratio indicates that 17.5 moles of oxygen are necessary for complete combustion of 3.5 moles of propane.
  • Understanding of the ideal gas law (PV = nRT)
  • Knowledge of stoichiometry and mole ratios in chemical reactions
  • Familiarity with significant figures and their application in calculations
  • Basic chemistry concepts related to combustion reactions
  • Study the ideal gas law applications in various conditions
  • Learn about stoichiometric calculations in combustion reactions
  • Review the rules for significant figures in scientific calculations
  • Explore common errors in chemical calculations and how to avoid them
Chemistry students, educators, and anyone involved in chemical calculations or laboratory work requiring precision in measurements and calculations.
STEMucator
Determine the volume of oxygen gas required to completely combust 3.5mole of propane in a barbecue at standard pressure and 28.0°C.
##PV = nRT##
My first question is, is the work I've done here still correct? http://gyazo.com/3a22ee323ec1edff0ea071255cf698ac
I'm a bit confused here. If i take the standard mole ratio route, I get a completely different answer. I would find that 17.5mole of oxygen would be needed for 3.5mole of propane. Then using the relevant equation I get 437.72925L = 400L because 100kPa only has 1 significant digit. This answer is clearly very far off.
This leads me to believe the question is intending me to do the work as I've shown in the image above.
Why does this incredibly different answer occur? Is it merely a fault of significant error? Or am i wrong completely and the mole route is appropriate (which really wouldn't make sense)?
If it is a standard pressure, 100 has at least three significant figures, if not infinitely many. Doesn't matter much, as 3.5 has only two and it is what limits number of digits on the final answer.
I don't see any difference between both approaches. I got 438 L in both cases, rounded down to 440 L. You got different final results as you rounded down intermediate results - never do that. Round down only the final result, use full precision during calculations.
Ah so I would keep the volume calculation at ##88L##. I thought because 100 had only 1 sig fig it would change the answer dramatically.
Doing that I get 440L directly by using the ratio 1/88 = 5/z.
No idea where you got 88 L from - unless it is already rounded 87.637. And I just told you to not round down intermediate results, haven't I?
Yes you're correct. I did round it.
I have a question now though just for clarity. Is it technically wrong to use significant figures in every step of a problem however many calculations there may be?
Yes, it is technically wrong. Round down only the final result, use full precision (or at least several so called guard digits) on all intermediate results. Otherwise you are introducing hard to detect errors (you have just witnessed such a situation).
Note - if you are REPORTING intermediate results, report them rounded.
9K
