Determining A Finite Value of Infinity
  • Context: Graduate
  • Thread starter Thread starter willr12
    Finite Infinity Value
The discussion revolves around the concept of assigning a finite value to the sum of all natural numbers, particularly in the context of the series 1 + 2 + 3 + 4... and its association with the value -1/12 through Riemann zeta regularization. Participants explore mathematical reasoning, challenge assumptions, and debate the implications of these ideas.
  • One participant proposes that if one accepts the sequence 1 + 2 + 3 + 4... = -1/12, then a finite value of infinity can be determined using the equation ((x^2) + x)/2.
  • Another participant argues that the series 1 + 2 + 3 + ... is divergent and does not have a sum, thus challenging the validity of assigning -1/12 as a sum.
  • Some participants emphasize that the assignment of -1/12 does not correspond to an actual sum and that regularization techniques do not imply equality with the divergent series.
  • Concerns are raised about the manipulation of infinite values, with participants noting that infinity is not a real number and cannot be treated like finite numbers.
  • There is a discussion about the distinction between regularization and representation, with one participant asserting that Riemann zeta(-1) is a regularization of the divergent series, not a representation of it.
Participants express significant disagreement regarding the validity of the claim that the series 1 + 2 + 3 + ... can be assigned a finite value. Multiple competing views remain, with no consensus reached on the interpretation of the series or the implications of its regularization.
Participants highlight limitations in reasoning about infinite sums and the need for rigorous proof when extending finite equations to infinite cases. The discussion reflects a range of interpretations regarding mathematical concepts and their implications.
willr12
okay...if you accept that the sequence
1+2+3+4...=-1/12,
I think I have determined a finite value of infinity.
To find the value of the sums of all natural numbers up to a number, you can use the equation
((x^2)+x)/2.
An example would be 4.
4+3+2+1=10.
((4^2)+4)/2 also equals 10.
following this logic,
((x^2)+x)/2=-1/12
is true for the above sequence. this can be rearranged to
(x^2)+x+1/6
This is the resulting quadratic equation. Using the quadratic formula, one obtains the x intercepts as
(-3+-(sqrt3))/6.
and since x is infinity in this situation (since the highest value is infinity), the x intercepts are the values of infinity in the equation. Therefore, by assigning a value of -1/12 to riemann zeta(-1), you also assign finite values to infinity, approximately
-0.211324...
and
-0.788675...
If there is any faulty reasoning, please remember I'm 15 and I most likely have no clue what I'm talking about.
Mathematics news on Phys.org
willr12 said:
I think I have determined a finite value of infinity...
Since this is a contraction in terms, I stopped reading right there.
1+2+3+4...=-1/12,
http://en.wikipedia.org/wiki/Divergent_series
There is no sum of the integers from one to infinity. The series is divergent. The assignment of the value -1/12 as the "sum" of this series does not correspond to anything which you should regard as being an actual sum.
Most people would stop reading when someone says that 1+2+3...=-1/12, that's counterintuitive but generally accepted...so thanks for the ignorance
Makes sense
1+2+3+4...=-1/12,
No. The series 1+2+3+... is divergent. So it is infinite.
It's Zeta regularization has value -1/12.
That is not the same thing as claiming that the series is "equal" to -1/12
((x^2)+x)/2.
4+3+2+1=10.
((x^2)+x)/2=-1/12
I fail to see how. Just because a statement is true for finite values of x does not mean it is valid for infinite values of x. You need to prove that "((x^2)+x)/2=-1/12" is a valid statement for some x. You have not.
This is not possible because (1) infinity is not a real number, (2) infinite values cannot be manipulated in the same way as finite values.
Unfortunately, everything.
Good to know. Thanks for the reply
willr12 said:
Most people would stop reading when someone says that 1+2+3...=-1/12, that's counterintuitive but generally accepted ...
No, as has been pointed out, it is NOT generally accepted.
It is generally accepted as a representation of Riemann zeta (-1)
No you have this backwards.
##\zeta(-1)## is a possible regularization of ##\sum_{n=1}^{\infty} n##.
##\sum_{i=1}^{\infty} n## is not a representation of ##\zeta(-1)##.
Regularization and representation are separate concepts.
Y-value of the vertex in the resulting quadratic equation is -1/12. Any significance do you think?
good to know thanks
1+2+3+4...=-1/12
I don't.
This thread has run its course, so I'm closing it.
  • · Replies 48 ·
