Determining Acceleration of Object on x-Axis
  • Thread starter Thread starter patelneel1994
    Acceleration
An object on the x-axis experiences constant acceleration, increasing its x-coordinate by 80 m in 5 seconds, with a final velocity of +20 m/s. The acceleration calculation appears to yield a negative value, which raises questions about the equations used. The discussion emphasizes the need to correctly apply kinematic equations, particularly distinguishing between uniform motion and accelerated motion. The initial velocity is unknown, complicating the use of certain equations, but the difference in position can be utilized. Clarifying these points is essential for accurately determining the object's acceleration.
patelneel1994
An object moving on the x-axis with a constant acceleration increases its x coordinate by 80 m in a time of 5.0 s and has a velocity of +20 m/s at the end of this time. Determine the acceleration of the object during this motion.
x = 80m t = 5.0 second v = + 20m/s a = while in motion
80 m = 100 m + 1/2 a 25 s2
-1.6 m/s2
Supppos to be positive I don't know why I get negative acceleration?
Can we apply this law?
Velocity is positive direction and if the velocity increases with time, then acceleration is said to be positive. In this case, if the velocity is reducing with time, then the acceleration said to be negative
Equation is not good. Where does the 100 come from?
This time, constant acceleration during 5 seconds gives an increase in velocity. There is an equation for that.
The other equation is the full expression for x(t). Two equations, initial velocity and acceleration unknown. Should be solvable.
is it Xt = X0 + V0 . t + 1/2 . a .t^2?
100 m came from 20 m/s . 5 s
#4 is correct.
In #5 you get meters allright, but that expression is for uniform (constant speed) motion. In this case the thing accelerates, so the average speed in these 5 sec was less.In #4 you don't know X(5) or X(0), but you know their difference, which is all you need.
You also don't know V(0) so you can't plug in a numerical value.
You still need an equation for V(t), where you plug in the knowledge that V(5 sec) = 20 m/s.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
