Determining bound states for delta function potential
The discussion focuses on determining bound states for a delta function potential described by the equation V(x) = -α[δ(x+a) + δ(x-a)] from Griffith's "Intro to Quantum Mechanics" (2nd Ed). The user initially misapplies boundary conditions and coefficients in their wave function solutions, particularly for regions defined by x < -a, -a < x < a, and x > a. The correct approach involves recognizing the symmetry of the potential, leading to symmetric and antisymmetric solutions, and correctly applying the boundary conditions to derive the wave function coefficients. The user also seeks clarification on the discontinuity in the derivative of the wave function at the delta function locations.
  • Understanding of quantum mechanics principles, particularly bound states and wave functions.
  • Familiarity with delta function potentials and their implications in quantum systems.
  • Knowledge of boundary conditions and their role in solving differential equations.
  • Ability to manipulate and solve the Schrödinger equation in one-dimensional potentials.
  • Study the properties of delta function potentials in quantum mechanics.
  • Learn about symmetric and antisymmetric wave functions in quantum systems.
  • Explore the method of solving differential equations using boundary conditions.
  • Investigate the implications of discontinuities in wave function derivatives at potential boundaries.
Students and practitioners of quantum mechanics, particularly those studying bound states in quantum systems, as well as educators looking to clarify concepts related to delta function potentials and wave function behavior.
Logan Rudd
I'm working on a problem out of Griffith's Intro to QM 2nd Ed. and it's asking to find the bound states for for the potential ##V(x)=-\alpha[\delta(x+a)+\delta(x-a)]## This is what I'm doing so far:
\mbox{for $x\lt-a$:}\hspace{1cm}\psi=Ae^{\kappa a}\\
\mbox{for $-a\lt x\lt a$}\hspace{1cm}\psi=Be^{-\kappa x}+Ce^{\kappa x}\\
\mbox{and for $x\gt a$:}\hspace{1cm}\psi=De^{-\kappa a}
However, this is what the solution reads:
\mbox{for $x\lt a$:}\hspace{1cm}\psi=Ae^{-\kappa a}\\
\mbox{for $-a\lt x\lt a$}\hspace{1cm}\psi=B(e^{\kappa x}+e^{-\kappa x})\\
\mbox{and for $x\lt-a$:}\hspace{1cm}\psi=Ae^{\kappa a}
Can someone explain what I'm doing wrong - why they are getting the coefficients they are - and what I should be doing? Maybe go over the general way of approaching these kind of problems? I'm also wondering why they don't have the case for $x>a$?
Thanks
The missing case for ##x>a## has to be a typo - the first line of the solution has a ##<## where ##>## was intended.
You will make more headway with the constants if you impose the additional condition that ##\psi## has to be symmetric or anti-symmetric. These constraints are OK because the potential is symmetric and the solution for a symmetric potential can always be written as a linear combination of symmetric and antisymmetric solutions.
Thanks! That makes it much clearer. I figured it was a typo but was kind of confused to begin with.
After this I am trying to figure out what ##\Delta\left(\frac{d\psi}{dx}\right)## is. Integrating the potential part of SWE and taking the limit as ##\epsilon## approaches ##\pm a## I get:
\Delta\left(\frac{d\psi}{dx}\right)=-\frac{2m}{\hbar ^2}\left[\alpha\psi(a)+\alpha\psi(-a)\right]
but the solution reads ##\Delta\left(\frac{d\psi}{dx}\right)=-\frac{2m\alpha}{\hbar^2}\psi(a)##
I think I'm close but not sure how they got their result. Do you see what I'm doing? Can you correct where I made any mistakes?
Look for solutions to the Schrödinger equation that work everywhere except at the two points where the potential is not zero. By inspection (also called "lucky guess" or "thoughtful selection of ansatz" or "the way most differential equations get solved") these have to be linear combinations of ##e^{kx}## and ##e^{-kx}##. Your boundary conditions tell you that ##\psi## goes to zero as ##x## goes to infinity in either direction; and you allowed to assume that the solution is either symmetric or antisymmetric. Those conditions are sufficient to determine which linear combinations (that is, what the coefficients are) of ##e^{kx}## and ##e^{-kx}## are solutions in the three regions of interest.
If find yourself tiring of the PhysicsForums rule that we will help you find the solution yourself but won't just give you the answer... Google will find a bunch of solutions. But I hope you'll keep working at it yourself - you are a differential equation away from victory.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 61 ·
