Determining direction of wave propagation from the phase?
The phase of a wave, represented by φ1 = k·r - ωt, indicates that the wave propagates in the direction of the wave vector k. Conversely, a phase described by φ2 = k·r + ωt suggests propagation in the opposite direction, -k. The distinction arises from the sign in front of the ωt term, which affects the time progression convention. To determine the wave's velocity, one can differentiate the phase with respect to time, yielding the phase velocity as dx/dt = ω/k. Therefore, the direction of wave propagation is directly linked to the orientation of the wave vector k.
AxiomOfChoice
Suppose you know the phase of a wave is given by
<br /> \phi_1 = \vec k \cdot \vec r - \omega t.<br />
How can you determine in which direction this wave is propagating? I guess, more specifically, how does a wave described by this phase differ from a wave described by the phase
<br /> \phi_2 = \vec k \cdot \vec r + \omega t<br />
I may not have provided enough detail...please tell me if I haven't! Thanks.
(I was always under the impression that it was the wave vector \vec k that carried the information about which way the wave was propagating, but recent discussions in my E&M class have caused me to question this belief.)
You first need to define your time progression. If your standard is good ole e^{-i\omega t}, then the phase dependence is given by:
\mathbf{k}\cdot\mathbf{r}-\omega t
The wave propogates in the \hat{k} direction. If you have
as your phase progression then you must have changed your time convention to e^{i\omega t} or you are missing a minus sign here where the actual dependence is e^{-\phi_2} in which case we are progressing in the -\hat{k} direction, but this information is not given in what you have.
Take r vector to be in the direction of k vector.
Now, take kx-wt=A (some constant phase) and differentiate it with respect to t . you get dx/dt=w/k which is the velocity of the point whose A(phase) is constant, and hence velocity of wave . It is called phase velocity. Direction of the propagation is the direction of k vector.
http://www.actionurl.com/jpxp
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 32 ·
