Determining force required to rip or tear sheetmetal
  • Thread starter Thread starter Spoolx
    Force Rip
The discussion focuses on calculating the force required to prevent tearing in sheet metal due to the application of a gas cylinder. The user calculates the maximum force (Fmax) using the formula stress = F/A, assuming a yield stress of 100 ksi and a sheet metal thickness of 1/6". However, the calculated Fmax of 12,500 lb appears excessively high compared to the actual force applied by the gas shock. Participants suggest that the attachment method (bolted with 4 screws) and the stress concentration at the mounting location are critical factors in determining the failure point.
  • Understanding of stress and strain concepts in materials science
  • Familiarity with yield stress calculations
  • Knowledge of mechanical fastening methods, specifically screw pull-out strength
  • Basic principles of fatigue failure in materials
  • Research "calculating screw pull-out strength" to assess attachment reliability
  • Study "stress concentration factors in bolted joints" for accurate load distribution
  • Explore "fatigue failure analysis in sheet metal" to understand long-term effects
  • Learn about "material selection for structural integrity" to improve design robustness
Mechanical engineers, structural designers, and anyone involved in the design and analysis of sheet metal components under load conditions.
Spoolx
Hi All.
I am working on a problem at work that is basically sheetmetal tearing due to a force being applied.
We have a sheetmetal door which we added a gas cylinder to help lift, the problem is the sheetmetal is tearing at the mounting location of the gas cylinder.
I know that the stress is causing the failure and that increasing the thickness of the mounting location will solve the problem but i want to wrap some formulas around it to make sure I am going big enough.
Any help or guidance on what formulas to apply here?
Thanks
I do the basic calculation of Fmax using stress = F/A
Assuming Yield stress = 100ksi, the sheet metal being 1/6" thick and the flange being 2" tall
100ksi=F/(2*.0625) -> F=100ksi*.125 -> Fmax =12500lb
This seems way wrong considering the gas shock only applies a few pounds of force. Am I calculating it wrong? If not how do I apply it to the fatigue failure?
Thanks
How is the gas shock attached to the panel? Weld, screws, or what? This will make a lot of difference.
The calculation you showed almost certainly included too much area supporting the load.
It's bolted to the plate with 4 10-32 screws.
I assume it is almost line to line contact and has a huge stress riser. Just not sure how to calculate.
Then is it not true that the critical issue is the pull-out strength of the 4 screws? It would seem that you might estimate the load required to rip out one screw, and then figure that the four screw combination will support no more than 4 times the individual screw load.
I would say no because the sheet metal is tearing at the bottom of the bracket.
You still have not shown us a picture, so it is impossible to make any meaningful comments on this matter.
  • · Replies 27 ·
9K
