Undergrad Determining if an operator is degenerate
To determine if an operator is degenerate, one can analyze its eigenvalue spectrum, typically using the equation det(Q - λI) = 0, where Q is the operator. For differential operators like -ħ(d²/dx²), the equation can be expressed as a differential equation, leading to solutions that include sine and cosine functions. Degeneracy often arises from symmetries, such as translation invariance, which results in multiple states sharing the same eigenvalue. Advanced group theory can help identify symmetries systematically, while "accidental" degeneracies may exist without clear symmetry causes. Understanding these concepts is crucial for analyzing the properties of operators in quantum mechanics.
Physgeek64
Hi,
I was wondering how you can formally determine whether a given operator is degenerate. I undertand you can produce the 'usual equation' det(Q-##\lambda ##)=0 and solve for ##\lambda ##, where Q is our operator. But if Q is a differential (for example ##\frac{p^2}{2m}= - \bar{h} \frac{d^2}{dx^2}## ) how can one write such an equation.
p.s. I only used this example as I know that the operator is degenerate with sin and cos of the same argument. Other examples are welcome :)
Many thanks in advance!
Also- don't know why I can't get my equations to format properly? ^^
< Moderator's note: fixed. You had a ( instead of { >
Degeneracy of an operator's eigenvalue spectrum is usually a result of some symmetry. In your example the operator ##\frac{d^2}{dx^2}## is translation invariant which means that the set of all displaced sine functions of same wavelength, ##sin(a x + b)##, is a set of mutually degenerate states (a is kept constant and b can have any real value).
hilbert2 said:
Degeneracy of an operator's eigenvalue spectrum is usually a result of some symmetry. In your example the operator ##\frac{d^2}{dx^2}## is translation invariant which means that the set of all displaced sine functions of same wavelength, ##sin(a x + b)##, is a set of mutually degenerate states.
Ahh okay that makes sense in this case. In general, do you know how this can be formally determined for any given operator (other than looking for a symmetry)?
^ There are probably some methods to systematically find all the symmetries of a differential operator, but that's quite advanced group theory. There are also so called "accidental" degeneracies that aren't caused by symmetries, but there's probably no efficient way to find them if they exist.
Likes vanhees71
As a differential equation. For example, in your case we would have, for a function ##f(x)##,
- \hbar^2 \frac{d^2}{dx^2} f(x) - \lambda f(x) = 0
which obviously has solutions for ##f(x)## that are sines and cosines. This still doesn't guarantee finding a solution, since solving differential equations is not a completely mechanical process. But that's how you would start.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 31 ·
