Determining instantaneous velocity from a graph
3 replies · 43K views
312213
This is how my problem has been presented:
The position of a rabbit along a straight tunnel as a function of time is plotted in Fig. 2-26.
http://img134.imageshack.us/img134/8263/graphxt5.th.jpg http://g.imageshack.us/thpix.php
Determine its instantaneous velocity at the following times.
(b) t = 32.5 s
2. The attempt at a solution
Attempts are:
0.49231 m/s
0.50769 m/s
0.523077 m/s
0.53846 m/s
0.553846 m/s
0.56923 m/s
0.57085 m/s
0.5846 m/s
The numbers are obtained, though rounded, for x/32.5 s, where x is, and in order:
18.552625 (obtained by count pixels and some math to get a number, though it failed)
The problem is probably just because the graph is terrible for this kind of work, due to the fact that the graph came off some different problem that was intended for students to describe the graph, so the numbers aren't very well set.
These are the numbers I obtained off the few weeks of physics I had but any other input is fine.
Its also fine to give a guess off the top of your head, so i can try it, but please base it off something.
To find instentanious velocity just draw a tangent to the graph at that specific time and calculate the tangents slope
So just to be sure, it would be a line from a point (I used 0,0) through tangent to the point at 32.5s (which would be the middle of the line, since it is about 5 pixels wide).
Also that it would look like this picture, more or less.
http://img515.imageshack.us/img515/2900/graph2mg6.th.jpg http://g.imageshack.us/thpix.php
If so, then I do get a new number, 0.57143 m/s at 18.57 m.
Thanks for your input.
Yes that would roughly be it. However I think the tangent line should be a bit higher.
