Determining number of branch cuts of a function
  • Thread starter Thread starter muppet
    Branch Function
The function f(q) is defined as an integral involving real-valued vectors and an infinitesimal epsilon, and the author believes it has two branch cuts. They express uncertainty about confirming this due to the lack of obvious fractional exponents and the complexity introduced by multiple dot products in the denominator. The author considers switching to hyperspherical coordinates to identify potential logarithmic behavior but struggles with defining angles consistently. After further reflection, they suspect there may only be one branch cut instead. The discussion centers on methods to analyze the function's branch cuts effectively.
muppet
Hi all,
I've reason to believe that the function
<br /> f(q)=\int\frac{d^{4+n} k}{(2\pi)^4}\frac{1}{(a \cdot k -i \epsilon) (b \cdot k -i \epsilon) (k^2 -i \epsilon) ((q-k)^2-i\epsilon)}<br />
where a, b are real -valued 4+n component vectors; epsilon is real, positive and infinitesmal, and taken to zero at the end of the calculation; and the dot denotes contraction of the vectors with the Minkowski bilinear form defined by Diag(-1,1,1,1), has two branch cuts. (As a physicist, I want to think of q and k as real (four+n)-component vectors as well, but I think it's necessary to extend these to allow to complex values.)
How can I go about finding out whether or not this is true? There's no obvious fractional exponents; my instinct is to switch to hyperspherical polars and see whether I get logarithms, but I'm thwarted by the fact that I have multiple dot products in the denominator, and don't know how to define the angles that would arise consistently.
Thanks in advance for your help.
Actually, after a little further thought I think it's only one branch cut...
  • · Replies 16 ·
