Determining the distribution function
4 replies · 3K views
shan
I've gotten a weird answer after doing the problem but I'm stuck as to where I messed up.
The density function is this:
[tex]f_{X} (x) = \frac{1}{6}x[/tex] for [tex]0<x\leq2[/tex]
[tex]= \frac{1}{3}(2x-3)[/tex] for 2<x<3
and 0 otherwise
And the question is to find the distribution function.
So integrating for the first part from 0 to x:
[tex]\int \frac{1}{6}u du = \frac {1}{6} \frac{x^2}{2} = \frac{x^2}{16}[/tex]
for 0<x<=2
I have a big problem with the second, part. This is what I did (integrating from 2 to x):
[tex]\int \frac{1}{3} (2u-3) du = \frac{1}{3} [u^2-3u] = \frac{1}{3} (x^2-3x - (2^2-6)) = \frac{x^2}{3} - x + \frac{2}{3}[/tex]
for 2<x<3
I know my answer for the second part is wrong as when x=2, the distribution function = 0 and when x=3, the distribution function = 2/3. But the distribution shouldn't be broken up like that at x=2 and supposedly at x=3, it should = 1. So did I forget to do something to the end points or did I not integrate properly?
Discussion
The distribution function is given by:
[tex]F_X(x) := \int_{-\infty}^x f_X(x) \, dx[/tex]
So when you computed [itex]\int_2^x f_X(x) \, dx[/itex], you computed the wrong thing, and there's no reason you should have gotten the right answer.
P.S. 6*2 is not 16.
Hurkyl said:
P.S. 6*2 is not 16.
whoops sorry, typo :blushing: that first part is
[tex]\int_0^x \frac{1}{6}u du = \frac {1}{6} \frac{x^2}{2} = \frac{x^2}{12}[/tex]
which shows I don't really understand what I'm doing but now that you mentioned it...
is the second part then given by [tex]\int_0^2 \frac{1}{6}u du + \int_2^x \frac{1}{3} (2u-3) du[/tex]? ie I forgot to add the first part of f(x)?
Right. Of course, there should also be a [itex]\int_{-\infty}^0 f_X(u) \, du[/itex] component as well. (But you know it's zero, so I suppose that's why you left it out)
Thank you very much for your help :)
