What Is the Phase Constant of the Wave?
  • Thread starter Thread starter smpolisetti
    Constant Phase
The discussion revolves around determining the amplitude and phase constant of a wave based on a provided diagram. The amplitude is related to the vertical axis measurement of 8 cm, while the horizontal axis indicates a time period of 3 seconds. Participants suggest using the wave equations x(t) = A sin(ωt + φ) or x(t) = A cos(ωt + φ) to find the phase constant. There is a need for clarification on which equation to use based on the context of the problem. The conversation highlights the importance of accessible diagrams for solving such wave-related questions.
smpolisetti
If the vertical axis blocks are 8 cm each and the horizontal axis blocks are 3 s each, what is the amplitude (in cm) of the wave shown in the diagram
http://i54.tinypic.com/2ilngr9.gif
What is the phase constant (in degrees) of the oscillation in the diagram?
Ø = wt + Ø0
I have nooooo idea where to start
I got that w is 0.35, but I don't know about Ø or Ø0
Perhaps you could start by posting a diagram that is accessible and is not at a site that needs your userID and password.
Sorry! I didn't realize it required a password
Excellent. The phase is the argument of a sine or cosine. You could write the expression that you are seeking in two ways,
1. x(t) = A sin(ωt+φ)
2. x(t) = A cos(ωt+φ)
Which of the two do you think the question wants you to use? You could use either one, each expression will have the same A and ω, but different φ. So if you are required to give an answer to a computer program, you have to know which expression it expects.
16K
