Determining the time of a collision
  • Thread starter Thread starter robertmatthew
    Collision Time
To determine the time of contact between a bat and a baseball, the initial calculation used the change in momentum formula, but the user initially overlooked the need to account for the direction of velocities. The correct approach involves recognizing that the difference in velocities is 82 m/s when considering the sign of the velocities. The user expressed confusion over their initial error but received reassurance from the community that such mistakes are common and part of the learning process. Ultimately, understanding the correct application of the formula is crucial for solving the problem accurately. The discussion highlights the importance of careful consideration of velocity signs in physics problems.
robertmatthew
A 473-gram baseball traveling at 37 m/s is hit directly back at the pitcher with a speed of 45 m/s. If the force of contact between the bat and the ball is 3800 Newtons, how long is the bat in contact with the ball?
F= dp/dt
F=dp/dt
t=dp/F
t=(m)(v2-v1)/F
t=(.473)(8)/(3800) ---> converted 473g into kg because Newtons are kg*m/s2
t=.000996 s
But that's not the right answer. I've also tried not converted g->kg and that doesn't work either, so obviously there's something else I'm doing wrong, but I just don't know what it is.
F= dp/dt
F=dp/dt
t=dp/F
t=(m)(v2-v1)/F
t=.000996 s
The difference in velocities between 37m/s towards the bat and 45m/s away from the bat is 82m/s. You have to consider the sign of the velocities.
Wow, that completely went over my head... now I feel really stupid, haha. Thanks for pointing that out, sorry for the waste of a post.
Don't feel sorry. That's what the forum is for. If you get it the post is hardly wasted.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 42 ·
  • · Replies 23 ·
  • · Replies 17 ·
