Determining Work from E-field Graph
In summary, a 0.5 µC charge was moved from A to B. The area under the curve from A to B was found to be 9 times the potential difference. The attempt at a solution involved a series of triangles/rectangles and found several results for the area (delta V) that ranged from 12V(certainly to small) to 18V(certainly to big). The equation of the line from A to B was found to be KQ/r2, where K is coulombs constant (8.85*109), Q is the unknown charge producing that field, and r is of course the radial distance in meters.
Dopefish1337
47
http://img413.imageshack.us/img413/8307/prob01a.gif
Determine the work done on a 0.5 µC charge moved from A to B.
delta V= -integral(E*dl), aka the area under the curve on an E-field graph from A to B equals the potential difference. (Sorry, don't know how to display math properly on these forums yet.)
(delta V)*(q)=Work
I've attempted to aproximate the the area under that curve 9 times now (from A to B) using a series of triangles/rectangles, and have gotten several results for the area (delta V) that ranged from 12V(certainly to small) to 18V (certainly to big).
I've been largely ignoring the sign's of things throughout, as the field is clearly from a positive charge, and so moving a 0.5*10-6 C charge closer to it will surely result in a positive amount of work done in the end. Is there any error in this reasoning, such that I should only be trying negative results?
Is there a better way to find the work done beyond attempting to aproximate the area? It makes theoretical sense to me so it 'should' work, but the absence of particularly precise y-values on the graph make it difficult, and it seems unreasonable of them to want a very accurate answer (which I presume they do, based on my first 9 tries being rejected) considering they didn't give us the equation of the graph.
Final answers I've tried ranged from 6.00*10-6 J to 8.00*10-6 J, but I've foolishly neglected to write down exactly what all I've tried because I was confident that my method was sound and it'd have a large range of acceptable answers to account for the aproximation of the area, but apparently not.
As you said the area under the graph is potential difference. Is there some way to present the electrical field so that it would help you to intergrate?
I believe the equation of that line would be something for the form KQ/r2, where K is coulombs constant (8.85*109), Q is the unknown charge producing that field, and r is of course the radial distance in meters.
That would integrate to -KQ[1/rA-1/rB], (assuming I'm not doing something wrong), so the answer I'd want is KQq[1/rB-1/rA]. (could someone check that integration, it 'feels' wrong for some reason?)
However, there doesn't appear to be any clear point from which I could determine the value of Q from in the first place, so I'm hesitant to switch my aproximations from area to aproximations of charge, as I only have 6 more tries left.
According to Newton's 3rd law every force has its counter-force. So couldn't you just reverse your thinking, and bring the electrical field closer to the charge? This is just my reasoning, so don't take my ideas for granted. I'm brainstorming with you. =)
I'm pretty sure that while correct, that would still have the same issue of the unknown charge that's producing the field, and would perhaps switch the sign of the answer.
Speaking of sign, are we in agreement that the final answer should be positive?
Yep, that should hold true.
Alright, I managed to get 'close enough' by taking (2,25) as a point on the graph to find Q, and then using that knowledge to integrate. The actual answer was slightly less (7.49E-6 C versus my input 7.50E-6 C) suggesting that even that point wasn't perfectly accurate, but at least it was close enough. :smile:
Was that the method they were looking for or was it solved some other way?
I don't know of any other relationship between E and work (and I certainly looked!), so I presume they must have expected us to use the method of finding Q and integrating. I imagine it'd be possible to get it through finding an aproximate area, but one would have to get fairly lucky and/or be fairly accurate to get it this way.
I'll inevitably be helping a few of my classmates with this problem in a week or two (that is to say, the day it's due), and I expect I'll be encouraging the method of finding Q from the closest 'good' point and integrating with that. If that doesn't work though, I don't know what I'd recommend. I suspect it'll work though.
What is a work from E-field graph?
A work from E-field graph is a visual representation of the relationship between the electric field and the work done by that field. It shows how the work done on a charged particle changes as it moves through the electric field.
How is work determined from an E-field graph?
To determine work from an E-field graph, you can use the formula W = qEd, where W is the work done, q is the charge of the particle, E is the electric field strength, and d is the distance the particle moves in the field.
What information is needed to create an E-field graph?
To create an E-field graph, you will need to know the strength and direction of the electric field, the charge of the particle, and the distance it travels in the field. This information can be obtained through experimentation or from theoretical calculations.
What does the slope of an E-field graph represent?
The slope of an E-field graph represents the strength of the electric field. A steeper slope indicates a stronger electric field, while a flatter slope indicates a weaker electric field.
How can E-field graphs be useful in scientific research?
E-field graphs can be useful in scientific research because they allow us to visualize and analyze the relationship between the electric field and the work done by that field. They can also help us make predictions and understand the behavior of charged particles in different electric fields.
