Determinism, realism, hidden variables
208 replies · 23K views · last reply
Paul Colby said:
The terms "physical" and "objective" are being used here for their emotional content.
No, they're not. I don't know what it is about QM that makes people say ridiculous things that they would never say if the subject were classical physics.
Let me illustrate the difference. Alice and Bob each draw a card from a standard 52-card deck, thoroughly shuffled. The objective facts are:
Alice has the ace of spades.
Bob has the three of hearts.
Alice might say: "Bob has a 49% chance of having a black card, and a 51% chance of having a red card."
Bob might say: "Alice has a 49% chance of having a red card, and a 51% chance of having a black card."
Those numbers are subjective--they are facts about Alice and Bob's knowledge. Actually, Bob definitely has a red card, and Alice definitely has a black card; the probabilities reflect their lack of information about the true state of affairs.
The distinction between subjective and objective is not a matter of emotional content. Sheesh.
Because it is very much not classical physics. The answer to the question I previously quoted is; yes, it's a fact.
The same holds in the QM measurement. If Alice measures and eigenvalue then the state of the unmeasured particle is known to Alice only and therefore subjective. Bob then makes a measurement and determines an outcome whose probability is know to Alice. So what?
Ilja said:
It is only realistic and causal.
Ok, so what would happen if I was to turn the question on its head ? We have discussed how macroscopic observers make measurements on quantum systems, and interpret the results and correlations. You say that quantum systems ( such as our EPR pairs ) can best be understood in a realistic and causal way; if that is the case we should be able to change the question, and ask how the quantum system itself would see/measure the rest of the universe ? Essentially, in analogy to riding rays of light in Special Relativity ( or at least playing catch-up with them ), I am wondering what it would be like to ride a quantum object ? How would I perceive the rest of the universe ? What would it be like for me to be entangled with another quantum object ? If QT is both realistic and causal, then it should be possible and meaningful to ask this question, no ?
Ilja said:
Please don't ask me anything about MWI. I'm unable to explain something about MWI using only decent language. It is simply inconsistent as an interpretation. Probabilities make sense only as a plausible expectation about what happens. If everything happens, it makes no sense at all.
I don't see why probabilities only make sense that way. You can only confirm your expectation by doing a run of similar experiments. So everything happening - mostly in other worlds - doesn't affect your measurement of the distribution in *your* world. In other words the observed distribution is identical to that of a true probability distribution even though it's actually caused by deterministic branching.
Ilja said:
MWI rejects every argumentation once it does not like the results (that means, in particular, Bell's theorem) but on the other hand uses common sense postulates from the justification of Bayesian probability theory to justify the claim that they can somehow derive the Born rule. IMHO not more than an actual illustration how one can derive everything from a theory with contradictions.
Since when does MWI reject Bell's theorem? I thought it just rejected one of the conditions for the theorem to apply. Or are you just talking about the Wheeler interpretation (see comment by Demystifier) and not talking about relative states?
So what - the eigenvalue is of an operator that Alice has only just that moment chosen. For your argument to be valid, Bob's particle would have to be in an eigenstate of all possible operators at once.
Only if you ignore the way things work. Alice knows the component of the entangled state once the eigenvalue of her particle is revealed. Knowing this she knows the state of the particle that Bob will then measure. This isn't a classical probability problem, it's a QM one. This is the fundamental nature of quantum states and observables.
Paul Colby said:
Help me out here. A system in an eigenstate of observable ##A## has this mythical "element of reality" prior to measurement but only if ##A## is an measurement is performed?
No, the whole point of the EPR criterion for being an element of reality is that the value of a property at time [itex]t[/itex] can't depend on what happens after time [itex]t[/itex].
Let me make an analogy: Suppose I give you some powder and tell you that if you burn it, it will produce green smoke. That implies something about the chemical composition. If you decide NOT to burn it, it won't produce green smoke, but the chemical that would have produced the green smoke is still there.
stevendaryl said:
Okay, I can see that you have nothing to contribute to this discussion.
That's a subjective fact well known to me before I commented. People simply refuse to give up on classical pictures and struggle with the unavoidable consequences. Most people here feed on these discussions. This really shouldn't bother me but it leads to language being introduced that adds no content and often misleads. Should a simple classical mind friendly "interpretation" (i.e. model without content) be found, I really doubt it will be used. If a model beyond QM is found as a result, then I very much doubt it will be a return to classical ideas. More than likely it will be even less comprehendible than what came before.
Markus Hanke said:
But then again, this immediately brings to mind a finding from QFT in curved space-time : different observers may measure different numbers of particles within the same spacetime, depending on the observer's state of motion. If that is the case, then in what sense can the existence of particles be considered "real" or "elementary" ?
One possible interpretation is that relativity is not fundamental, there is a preferred Lorentz frame, so only particles defined with respect one frame are elementary, while those defined with respect to other frames are not much more than clicks in a detector. Another interpretation is that particles are not elementary at all, i.e. they are just clicks irrespective of the frame.
How on Earth does she know what Bob is going to measure in the future? Different polarizer angles are different bases. Bob hasn't chosen his yet.
It is this dependency on *both* angles (actually their difference) that makes it quite impossible to explain the violations of Bell's Inequality by local variables. The inequality doesn't have anything to do with how you describe the state. You can make Bob's state a herd of fairies waving their magic wands over it if you want to - as long as nothing from Alice can reach Bob (even by magic), it is impossible for the violations to occur unless either local causality is violated or Alice's outcome is not unique (as in RSF/MWI).
There is no well-defined process of branching and no well-defined history - which would be equivalent to a Bohmian trajectory, even if splitted (which one would have in a stochastic interpretation too). There is nothing which clearly distinguishes a branch - except the completely vague idea that it is something like an isolated wave packet, but it is doubtful that real wave functions split into localized packages instead of something very smooth. Roughly, you have nothing. Except a wave function. And whatever else from common sense one decides to use for some particular purpose.
They claim to be a realistic and Einstein-causal interpretation. But Bell's theorem holds for realistic Einstein-causal theories. So, they have to use some form of creative naming conventions or so (many words interpretation) to avoid Bell's theorem.
Bob's polarizer will react as if the particle was in a state which is now known by Alice. Bob still thinks the state is in a general entangled one and is none the wiser. I get that you find this mysterious. I don't because I've accepted QM as fundamental. QM states possessing their very own unique properties that aren't classical properties. When I was first confronted with the fact that the speed of light is independent of frame I had similar (identical) conceptual problems. But, the logic which 100% based on observations, dictate that space-time has this property. I got over it. QM very well (and almost assuredly is) just as fundamental. When I ask why is accepting SR so different than QM the replies boil down to because it doesn't conform to the way we think (or in some cases define) the world should work. I would suggest that people just accept the rules as fundamental for a week just as an exercise. If you find yourself asking but how did bob's measurement know...the answer is this is how the known state reacts to that measuring device.
Okay.
I say that to understand requires to describe it in a realistic and causal way. Everything else is mysticism, not understanding.
I don't know, and I don't think so. What would it be like to be attracted by Newtonian gravity for a particle? I don't know, even if I know Newtonian gravity IMHO good enough.
I didn't say anything about actual branching. Can we backtrack a bit and make the distinction which Demystifier brought up, between relative states and Wheeler's reinterpretation? I am happy to agree to the term MWI being reserved for Wheeler's nonsense, but in that case everything I've just said applies to relative states. You still get different "worlds" in RSF, the difference being that you, the commentator, not the observer, decompose a state in whatever basis you fancy. Often it will be sensible to use whatever the experiment sets out to measure, or else use the emergent preferred basis, but fundamentally you can use anything you like.
I don't see that MWI (unless you still mean Wheeler's version) rejects Bell's theorem. It is after all a theorem. It would be like rejecting 2 + 2 = 4. However for the theorem to be applicable, the kind of realism required is that "When I see a dog, it's a dog, not a ****ing kangaroo!" - which is, to put it mildly, a big assumption when we are dealing with a theory a) of observations and b) in which superposition is fundamental. Do you not agree?
I really don't know where you get the idea that I or anyone else here does not agree that QM is fundamental. It is a total waste of time explaining that we need to accept what we already accept.
Its hard, I have never seen an MWI variant which made sense for me, and so I have to acknowledge that I have not tried hard to distinguish the variants. My main criticism was that they need additional structure to make sense at all, but that I have never seen a variant which really specifies the additional structure(s) which are required.
They claim "MWI is a realist, deterministic, local theory" even on the Wiki level. Its not my job to make their claims compatible with Bell's theorem.
But what I have seen, they can simply claim that Bell's theorem is not applicable, and it is hard to question this given that Bell's theorem requires a meaningful notion of probability theory, and this is nothing one can reasonably claim that it exists.
On the other hand, they use some common sense postulates to argue they have enough probability theory to prove the Born rule.
If this is accepted then why do you ask,
because in QM, which you claim to accept, she knows the STATE of bob's particle and therefore may answer all statistical questions regarding Bob's eventual choice of polarizer before Bob chooses. What's not to understand?
I think it is a perfectly reasonable question to ask what it would be like to "ride" a classical test particle under the influence of Newtonian gravity, and an easy to answer one too. If one assumes both realism and causality, it should likewise be possible to wonder what it would be like to "ride" a quantum particle ( never mind the entanglement thing for now ), and what the rest of the universe would look like from that perspective. I don't know the answer either, but it is an interesting question, though possibly not meaningful. I don't know.
Okay. To my simple understanding of relative states it makes sense without any additional structure.
MWI has probability - the expectation of particular statistics. What it does not have is absolute outcomes - typically a measurement results in an entanglement. I don't see the problem with having emergent probability whilst asserting an ontic model which precludes applying Bell's Theorem. It's not as if it claims to violate the theorem, only that the necessary conditions are not met.
Ah yes, my bad. She knows the STATE of Bob's particle. Oops.
But that does not alter anything. She *knows* the state, no mystery. But she also has had a causal influence on it. From a distance instantly. And that is a serious problem.
Saying "that's just the way QM is" does not get around the fact that the EPR correlations are impossible given local causal definite-realism. If you are happy that at least one of them has to go because "that's just the way QM is" then fine, let's leave it at that. I prefer to ask what does this tell us is going on a bit deeper than "shut up and let me calculate the probabilities" :)
Even a subdivision into system and observer is already additional structure.
I see no base for such expectations. Maybe I'm blind, but I don't see it.
I don't see any probability emerging.
Claiming they are somehow realist and have a probability, but the EPR criterion of reality is somehow not applicable.
Alice's measurement is on the entangled state. The result of her measurement produces a pair in a product state. At this the measurement process is the exactly the same as measuring a ##z##-polarized particle along ##x##. Now, a common assumption is that the ##x##-measurement device physically kicks or "disturbs" each spin along ##z## into a spin along ##\pm x## kind of at random. That this is a deeply flawed classical imagining of the measurement process is amply underscored by exactly the class of argument you reference. For practical reasons one cannot measure things without some form of interaction with the thing being measured. However, I do not believe it is this unavoidable measurement interaction causes the selection of an individual eigenvalue.
You mentioned the factorization problem once before in terms of state space. I didn't get it then and I still don't. Which could easily be because I am not mathematical though I am trying to follow the principles that people mention! So let's cut to the chase. If we can take an arbitrary subspace of the global system's state space, what structure is needed to justify the assumption that at least one such (not every such) subspace is the state space of an observer? What is it about observer state spaces that makes it necessary to add something to QM in order for them to exist?
I do appreciate that a quantitative derivation of the Born Rule is controversial. But a qualitative emergence of probability is trivial. A sequence of observation yields a frequency for each outcome. That's all the probability one needs. Isn't it?
Paul Colby said:
Alice's measurement is on the entangled state. The result of her measurement produces a pair in a product state. .
I don't understand you. If the two electron state is |u>|d> + |d>|u> then Alice's measurement creates an entanglement of exactly the same form except that the first ket is now Alice's state not her electron's state. That's not a product. Neither can it be made into one without changing the basis from local variables like spin to non-local ones like two-electron entangled spins!
What you seem to be saying is that |u>|d> + |d>|u> appears to Alice to have collapsed to one or other of the products. But if the collapse is merely an appearence then there is no way you can say Bob's particle state has collapsed. It is in fact still entangled with the Alice system. But if you say the collapse is real and applies to Bob, then you have FTL propagation or causality.
The question is not that one can take some arbitrary subspace or not. The point is that one has to take it. And this choice of a subspace is necessary to define something which is claimed to have some status of reality - a split into different worlds. So, this choice of a subspace cannot be simply an arbitrary subjective and otherwise irrelevant thing, it has to be something real.
This is not the point. The point is that without additional structure nor observer state spaces nor system state spaces exist, but only a single global space without any structure.
The Copenhagen interpretation has, instead, a lot of additional structure, in the classical part it has a whole classical world full of it.
Which sequence? There are no sequences in a universe where everything always exists.
If the state is ##\vert u d\rangle+\vert d u\rangle## and Alice performs a measurement on particle 1 obtaining a ##u## eigenvalue, then the resulting state for the pair is ##\vert u d\rangle## which is very much a product.
Okay, I haven't the faintest idea what any of that means. Thanks for trying.
Yes that theory(!) assumes that Alice's measurement collapses the wavefunction non-locally.
You bring much to what is being said that really hasn't been said by me. The EPR measurement (FTL propagation problem as you put it) assumes a causal connection that just isn't there. Viewing QM measurement as some form of random interaction is a flawed concept unsupported by experiment.
