Developing a Circuit to Clip Triangular Wave at 5V
  • Thread starter Thread starter theuserman
    Circuit Wave
3 replies · 4K views
theuserman
Hey everyone, I need some help with this problem. A triangular wave generator produces a waveform (triangular wave with peaks of 10 V). I need to develop a circuit that clips the voltages at 5 V (ie, they become flat at 5V). We're allowed to use DC voltages of +10 V and −10 V as well as resistors, capacitors (although I don't see why we would need to) and standard signal diodes (so in other words, no zener diodes).
I was trying to do something similar to what was instructed here (3rd circuit shown): http://www.allaboutcircuits.com/vol_3/chpt_3/6.html
I might just need a kick in the head or something to get my head around this. My general problem is that I set it up like the one that clips at 2V and -3V - however since I'm limited to 10V DC batteries, I get clipping at 10.7V... I was wondering if it would be possible to perhaps use resistors to dissipate 5.7 V?
Also, it's been a while since I did this so in the link I gave is the 1 Kohm resistor there just to be a load resistance and make sure the diodes don't burn out? Or does it play some other role?
Thanks.
Can't you use more than one diode to get the clamp voltage you are looking for?
I suppose, but that wouldn't give me exactly 5 V... would it? Are you just suggesting I stack the diodes?
I was thinking, since I'm constrained to use 10 V batteries what if I made some voltage dividers and stuck the output voltages where I want the specialized batteries to be? Essentially fashion a 5.(whatever) battery out of a 10 V battery and put 110 Ohm resistor as the load resistor and 140 Ohm resistor with the 10 V battery.
