Diagonalising Matrices / Recurrence Relations
15 replies · 5K views
Ted123
[PLAIN]http://img530.imageshack.us/img530/6672/linn.jpg
For parts (a) and (b) I've found the eigenvalues to be [itex]-\frac{1}{3}[/itex] and [itex]-1[/itex] with corresponding eigenvectors [itex]\begin{bmatrix} -1 \\ 3 \end{bmatrix}[/itex] and [itex]\begin{bmatrix} -1 \\ 1 \end{bmatrix}[/itex] respectively.
Now for part (c) I know there is a way of solving this by diagonalising matrices but I can't remember the method.
The recurrence relation can be written as [itex]\begin{bmatrix} a_n \\ a_{n-1} \end{bmatrix} = \begin{bmatrix} -\frac{4}{3} & -\frac{1}{3} \\ 1 & 0 \end{bmatrix} \begin{bmatrix} a_{n-1} \\ a_{n-2} \end{bmatrix}[/itex]
We can diagonalise [itex]A = \begin{bmatrix} -\frac{4}{3} & -\frac{1}{3} \\ 1 & 0 \end{bmatrix}[/itex] by:
letting [itex]D = \begin{bmatrix} -\frac{1}{3} & 0 \\ 0 & -1 \end{bmatrix}[/itex] and [itex]P = \begin{bmatrix} -1 & -1 \\ 3 & 1 \end{bmatrix}[/itex] so that we have [itex]A= PDP^{-1}[/itex]
Now how do I find [itex]a_n[/itex] from here?
I'll give a hint:
[tex]\left( \begin{array}{c} a_n\\ a_{n-1} \end{array}\right)=\left( \begin{array}{cc} -\frac{4}{3} & -\frac{1}{3}\\ 1 & 0 \end{array}\right)\left( \begin{array}{c} a_{n-1}\\ a_{n-2} \end{array}\right)=\left( \begin{array}{cc} -\frac{4}{3} & -\frac{1}{3}\\ 1 & 0 \end{array}\right)^2\left( \begin{array}{c} a_{n-2}\\ a_{n-3} \end{array}\right)=??\left( \begin{array}{c} a_1\\ a_0 \end{array}\right)[/tex]
micromass said:
I'll give a hint:
[itex]\begin{bmatrix} a_n \\ a_{n-1} \end{bmatrix} = A^{n-1} \begin{bmatrix} a_1 \\ a_0 \end{bmatrix}[/itex]
so how do I use the diagonalisation? EDIT: I see...
You use the diagonalization to calculate [tex]A^{n-1}[/tex]. For example
[tex]A^3=(PDP^{-1})(PDP^{-1})(PDP^{-1})=PD^3P^{-1}[/tex]
I get [itex]\begin{bmatrix} a_n \\ a_{n-1} \end{bmatrix} = \begin{bmatrix} -\frac{1}{3}\left( -\frac{1}{3} \right) ^{n-1} + (-1)^{n-1} \\ \left( -\frac{1}{3} \right) ^{n-1} - (-1)^{n-1} \end{bmatrix}[/itex]
Reading off the top component, is this the same as the printed formula?
Well, it requires some reworking. But it's the same thing. So it looks like you've solved it!
There's actually a further part to the question:
[PLAIN]http://img703.imageshack.us/img703/273/lin0.jpg
After multiplying through how do I 'compare coefficients'?
What happens if you multiply
[tex](x^2+4x+3)(a_0+a_1x+a_2x^2+a_3x^3+...)[/tex]
Multiply these things out. What you get, should be equal to x.
This gives:
[itex]2x = 3a_0 + (4a_0 + 3a_1)x + (a_0 + 4a_1 + 3a_2)x^2 + (a_1 +4a_2 +3a_3)x^3 + (a_2 +4a_3)x^4 + a_3x^5 + \cdots[/itex]
If we equate coefficients we see that
[itex]3a_0 = 0 \Rightarrow a_0 = 0[/itex]
[itex]4a_0 + 3a_1 = 2 \Rightarrow 3a_1 = 2 \Rightarrow a_1 = \frac{2}{3}[/itex]
I could keep going forever but how do I show that the coefficients satisfy the recurrence relation?
In general, what will the coefficient of xn be? You'll see your recurrence relation popping up...
In general the coefficient of [itex]x^n[/itex] is [itex]3a_n + 4a_{n-1} + a_{n-2}[/itex]
How does the link with the recurrence relation?
micromass said:
Yes. So what does an equal?
Well for [itex]n\in \mathbb{N} \backslash \{1\}[/itex] ,
[itex]3a_n + 4a_{n-1} + a_{n-2} = 0[/itex]
so [itex]a_n = -\frac{4}{3} a_{n-1} - \frac{1}{3} a_{n-2}[/itex]
which is precisely the recurrence relation!
The characteristic polynomial is given by
[itex]c_A (\lambda ) = \begin{vmatrix} \displaystyle -\frac{4}{3} - \lambda & \displaystyle -\frac{1}{3} \\ 1 & -\lambda \end{vmatrix} =0[/itex]
[itex]\Rightarrow (-\frac{4}{3} - \lambda ) \left(-\lambda \right) - ( -\frac{1}{3} ) ( 1) = 0[/itex]
[itex]\displaystyle \Rightarrow \frac{4}{3} \lambda + \lambda ^2 + \frac{1}{3} = 0[/itex]
[itex]\displaystyle \Rightarrow 3\lambda ^2 + 4\lambda + 1=0[/itex]
[itex]\displaystyle \Rightarrow (3\lambda +1)(\lambda +1)=0[/itex]
[itex]\displaystyle \Rightarrow \lambda = -\frac{1}{3}[/itex] or [itex]\lambda = -1[/itex]
[itex]\displaystyle \therefore -\frac{1}{3}[/itex] and [itex]-1[/itex] are eigenvalues of [itex]A[/itex]
The eigenvectors
[itex]\begin{bmatrix} x \\ y \end{bmatrix}[/itex] of A with eigenvalue -1/3 satisfy the vector equation
[itex]\begin{bmatrix} -1 & -\frac{1}{3} \\ 1 & \frac{1}{3} \end{bmatrix} \begin{bmatrix} x \\ y \end{bmatrix} = \begin{bmatrix} 0 \\ 0 \end{bmatrix}[/itex]
which is equivalent to the single linear equation [itex]x = -\frac{y}{3}[/itex]
Hence the eigenvectors of A with eigenvalue -1/3 are [itex]\begin{bmatrix} -\frac{y}{3} \\ y \end{bmatrix}[/itex] where [itex]y \neq 0[/itex]
The eigenvectors
Then
[itex]AP = \begin{bmatrix} -\frac{4}{3} & -\frac{1}{3} \\ 1 & 0 \end{bmatrix} \begin{bmatrix} -1 & -1 \\ 3 & 1 \end{bmatrix}= \begin{bmatrix} \frac{1}{3} & 1 \\ -1 & -1 \end{bmatrix}[/itex]
and
[itex]PD = \begin{bmatrix} -1 & -1 \\ 3 & 1 \end{bmatrix} \begin{bmatrix} -\frac{1}{3} & 0 \\ 0 & -1 \end{bmatrix} = \begin{bmatrix} \frac{1}{3} & 1 \\ -1 & -1 \end{bmatrix}[/itex]
and [itex]P[/itex] is invertible since [itex]\text{det}(P) = (-1)(1) - (-1)(3) - -1+3=2 \neq 0[/itex]
Now [itex]\begin{bmatrix} a_n \\ a_{n-1} \end{bmatrix} = \begin{bmatrix} -1 & -1 \\ 3 & 1 \end{bmatrix} \begin{bmatrix} -\frac{1}{3} & 0 \\ 0 & -1 \end{bmatrix} ^{n-1} \begin{bmatrix} \frac{1}{2} & \frac{1}{2} \\ -\frac{3}{2} & -\frac{1}{2} \end{bmatrix} \begin{bmatrix} a_1 \\ a_0 \end{bmatrix}[/itex]
[itex]= \begin{bmatrix} a_n \\ a_{n-1} \end{bmatrix} = \begin{bmatrix} -1 & -1 \\ 3 & 1 \end{bmatrix} \begin{bmatrix} (-\frac{1}{3})^{n-1} & 0 \\ 0 & (-1)^{n-1} \end{bmatrix} \begin{bmatrix} \frac{1}{2} & \frac{1}{2} \\ -\frac{3}{2} & -\frac{1}{2} \end{bmatrix} \begin{bmatrix} \frac{2}{3} \\ 0 \end{bmatrix}[/itex]
[itex]= \begin{bmatrix} a_n \\ a_{n-1} \end{bmatrix} = \begin{bmatrix} -(-\frac{1}{3})^{n-1} & -(-1)^{n-1} \\ 3(-\frac{1}{3})^{n-1} & (-1)^{n-1} \end{bmatrix} \begin{bmatrix} \frac{1}{3} \\ -1 \end{bmatrix}[/itex]
[itex]\begin{bmatrix} a_n \\ a_{n-1} \end{bmatrix} = \begin{bmatrix} -\frac{1}{3} ( -\frac{1}{3} ) ^{n-1} + (-1)^{n-1} \\ ( -\frac{1}{3} ) ^{n-1} - (-1)^{n-1} \end{bmatrix}[/itex]
Reading off the top component we see that [itex]a_n = -\frac{1}{3} ( -\frac{1}{3} ) ^{n-1} + (-1)^{n-1}[/itex]
[itex]a_n = -\frac{1}{3} ( -\frac{1}{3} ) ^n ( -\frac{1}{3} ) ^{-1} + (-1)^n (-1)^{-1}[/itex]
[itex]a_n = ( -\frac{1}{3} ) ^n - (-1)^n[/itex]
[itex]a_n = \frac{(-1)^n}{3^n} - (-1)^n[/itex]
[itex]a_n = (-1)^n \left( \frac{1}{3^n} - 1 \right)[/itex]
[itex]{\bf p}(t) = (f(t)\cos\,t,f(t)\sin\,t)[/itex]
[itex]{\bf p}'(t) = (f'(t)\cos\,t - f(t)\sin\,t , f'(t)\sin\,t + f(t) \cos\,t)[/itex]
[itex]\displaystyle \oint_C -\frac{y}{x^2+y^2} \; dx + \frac{x}{x^2+y^2} \; dy[/itex]
[itex]\displaystyle = \int^{\pi}_{-\pi} \left( -\frac{y}{x^2+y^2} \frac{dx}{dt} + \frac{x}{x^2+y^2} \frac{dy}{dt} \right) \; dt[/itex]
[itex]\displaystyle = \int^{\pi}_{-\pi} \bigg \{ \left( -\frac{f(t)\sin\,t}{f^2(t)\cos^2 \, t} + f^2(t) \sin^2 \, t \right) \left( f'(t) \cos \, t - f(t)\sin \, t \right)[/itex]
[itex]+ \left( \frac{f(t)\cos \, t}{f^2(t)\cos^2 \, t} + f^2(t) \sin^2 \, t \right) \left( f'(t)\sin \, t + f(t)\cos \, t \right) \bigg \} \; dt[/itex]
[itex]\displaystyle = \int^{\pi}_{-\pi} \left( -\frac{f(t)f'(t) \sin\,t\cos\,t}{f^2(t)} + \frac{f^2(t)\sin^2 t}{f^2(t)} + \frac{f(t)f'(t) \sin\,t\cos\,t}{f^2(t)} + \frac{f^2(t)\cos^2 t}{f^2(t)} \right) \;dt[/itex]
[itex]\displaystyle = \int^{\pi}_{-\pi} \left( \sin^2 t + \cos^2 t \right) \;dt[/itex]
[itex]\displaystyle = \int^{\pi}_{-\pi} \;dt = \left[ t \right]^{\pi}_{-\pi} = 2\pi[/itex]
2(a) Call the 3 sections of the curve C in the order described in the question [itex]C_1, C_2 ,C_3[/itex] respectively.
Then [itex]\displaystyle \int_C = \int_{C_1+C_2+C_3} = \int_{C_1} + \int_{C_2} + \int_{C_3}[/itex]
So parametrising [itex]C_1 , C_2 , C_3[/itex] as follows,
[itex]C_1[/itex] : For [itex]0 \leq t \leq 1\;,\;p(t) = (1-t)(0,0) + t(R,0) = (tR,0)[/itex]
[itex]p'(t) = (R,0)[/itex]
[itex]C_2[/itex] : For [itex]0 \leq t \leq \frac{\pi}{2}\;,\;p(t) = (R\cos\,t , R\sin\,t)[/itex]
[itex]p'(t) = (-R\sin\,t , R\cos\,t)[/itex]
[itex]C_3[/itex] : For [itex]0 \leq t \leq 1\;,\;p(t) = (1-t)(0,R) + t(0,0) = (0,R-Rt)[/itex]
[itex]p'(t) = (0,-R)[/itex]
Hence [itex]\displaystyle \int_{C_1} = \int_{C_1} \left( -xy^2 \frac{dx}{dt} + x^2y \frac{dy}{dt} \right)\;dt[/itex]
[itex]\displaystyle = \int^1_0 \bigg \{ (-tR)(0)(R) + (R^2)(0)(0) \bigg \}\;dt = 0[/itex]
[itex]\displaystyle \int_{C_2} = \int^{\frac{\pi}{2}}_0 \bigg \{ (-R\cos\,t)(R^2\sin\,t)(-R\sin\,t) + (R^2\cos^2t)(R\sin\,t)(R\cos\,t) \bigg \} \;dt[/itex]
[itex]\displaystyle = R^4 \int^{\frac{\pi}{2}}_0 \left( \cos\,t\,\sin^3t + \sin\,t\,\cos^3\,t \right) \;dt[/itex]
[itex]\displaystyle = R^4 \left( \frac{1}{4} + \frac{1}{4} \right) = \frac{R^4}{2}[/itex]
[itex]\displaystyle \int_{C_3} = \int^1_0 \bigg \{ (0)\left( (R-Rt)^2 \right)(0) + (0)(R-Rt)(-R) \bigg \} \;dt =0[/itex]
Hence [itex]\displaystyle \int_C = 0 + \frac{R^4}{2} + 0 = \frac{R^4}{2}[/itex]
[itex]\sin^3\,t[/itex] and [itex]\cos^3\,t[/itex]
2(b) Let [itex]P = -xy^2[/itex] and [itex]Q = x^2y[/itex]
Then Green's theorem says that [itex]\displaystyle \oint_C P\;dx + Q\;dy = \iint_S \left( \frac{\partial Q}{\partial x} - \frac{\partial P}{\partial y} \right) \;dxdy[/itex]
So (calling the integral I) [itex]\displaystyle I = \iint_S (2xy + 2xy) \;dxdy = \iint_S 4xy\;dxdy[/itex]
