Diagonalization and change of basis
3 replies · 2K views
RicardoMP
I have the following matrix given by a basis [itex]\left|1\right\rangle[/itex] and [itex]\left|2\right\rangle[/itex]:
[itex] \begin{bmatrix}<br /> E_0 &-A \\<br /> -A & E_0<br /> \end{bmatrix}[/itex]
Eventually I found the matrix eigenvalues [itex]E_I=E_0-A[/itex] and [itex]E_{II}=E_0+A[/itex] and eigenvectors [itex]\left|I\right\rangle = \begin{bmatrix}<br /> \frac{1}{\sqrt{2}}\\<br /> \frac{1}{\sqrt{2}}<br /> \end{bmatrix} and \left|II\right\rangle=\begin{bmatrix}<br /> \frac{1}{\sqrt{2}}\\<br /> -\frac{1}{\sqrt{2}}<br /> \end{bmatrix}[/itex].
I found out in the solutions of further problems that I can write these vectors as [itex]\left|I\right\rangle=\frac{1}{\sqrt{2}}\left|1\right\rangle+\frac{1}{\sqrt{2}}\left|2\right\rangle[/itex] and[itex]\left|II\right\rangle=\frac{1}{\sqrt{2}}\left|1\right\rangle-\frac{1}{\sqrt{2}}\left|2\right\rangle[/itex]
But why do we assume that [itex]\left|1\right\rangle=<br /> \begin{bmatrix}<br /> 1 \\<br /> 0<br /> \end{bmatrix}[/itex] and [itex]\left|2\right\rangle=<br /> \begin{bmatrix}<br /> 0 \\<br /> 1<br /> \end{bmatrix} ?[/itex]
Is this canonical basis, a basis of every matrix?
The column matrix representation of a state ##\newcommand{\ket}[1]{\left| #1 \right\rangle} \ket{\psi}## in a basis ##\ket{1}##, ##\ket{2}## is given by
\newcommand{\braket}[2]{\langle #1 | #2 \rangle}
\begin{pmatrix}
\braket{1}{\psi} \\ \braket{2}{\psi}
\end{pmatrix}
so clearly, if you want to represent the state ##\ket{1}## in this matrix representation, you would get
\begin{pmatrix}
\braket{1}{1} \\ \braket{2}{1}
\end{pmatrix} = \begin{pmatrix} 1 \\ 0 \end{pmatrix}
to be crystal clear, you have real symmetric matrix, with eigenvectors
##\mathbf v_1 \propto
\begin{bmatrix}
1\\
\end{bmatrix}##
and
##\mathbf v_2 \propto
\begin{bmatrix}
1\\
-1
\end{bmatrix}##
these are orthogonal to each other. If you choose to scale each by ##\frac{1}{\sqrt{2}}## then you may call them orthonormal -- in general this is extremely desirable and hence that is why it was rescaled.
This appears to be a question about conventions in the use of Dirac Notation, which is not a math question but something for the QM forums.
In general the use of standard basis vectors' coordinates is a common approach when dealing in finite dimensons. Technically for a relevant canonical form you'd look to the Jordan Canonical Form. I don't think using coordinates of the standard basis is canonical per se in math, but again your questions seems to be more about QM conventions than math.
No, it's an abuse of notation. A ket is an abstract vector, independent of any basis. Column vectors always refer to a basis. Obviously tacitly you assumed that the basis to use should be ##\{|1 \rangle,|2 \rangle \}##. Of course the components of the basis vectors wrt. this basis itself are the "canonical basis" vectors of ##\mathbb{C}^n## (in your case ##n=2##).
