Diagonalize matrix by unitary transformation
To find the eigenvalues of matrix A using a unitary matrix U, the relation U^(dagger)AU = D is established, where D is diagonal. The process involves ensuring U is unitary, which requires the orthogonality of eigenvectors. While the exercise suggests deriving eigenvalues through this method, it is acknowledged to be more complex than directly solving the eigenvalue equation. The discussion highlights the potential to eliminate eigenvector terms using cross diagonal equations from the provided PDF. Ultimately, the task remains challenging, but it emphasizes the connection between unitary transformations and diagonalization.
aaaa202
In an exercise I am asked to find the eigenvalues of a matrix A by demanding that a unitary matrix (see the attached file) diagonalizes it. I know I could just solve the eigenvalue equation but I think I am supposed to do it this rather tedious way.
Now I have introduced an arbitrary unitary matrix and performed the matrix multiplication:
U^(dagger)AU = D, where D is a diagonalized matrix.
From this last relation I should somehow be able to find the eigenvalues, but I haven't been able to so far. Have I done it wrong or is there actually a way through this messy algebra. What should I do?
Note that the unitarity demands that lu_kl^2+lv_kl^2 = 1, which I suspect could be useful, but are there any other relations, which I am missing?
To do this you somehow have to know the eigenvectors of A; these eigenvectors v_i would form your matrix U, i.e. U = [v_1 v_2 ... v_n]. Not really sure about the unitary matrix assumption..it could be just that by making D be unitary, then D is said to diagonalizable and therefore your equation U^T*A*U = D holds.
Oh you should check the wiki page for unitary matrices...there are some extra properties. The eigenvectors must be orthogonal.
But I am guessing you can write up a general unitary matrix U and then by demanding that it diagonalizes A, you can find the eigenvalues. At least that is how I think the exercise is thought, but it is much easier to just solve the eigenvalue equation.
yeah so from the pdf you uplinked that's exactly what is done. you have formulae for the eigenvalues in terms of the matrix elements from A and U. I assume you know A immediately, and maybe you can eliminate the eigenvector terms using the cross diagonal equations. The notation seems to be a bit excessive.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
  • · Replies 33 ·
