- 29,992
- 21,874
bahamagreen said:Summary:: Six sided fair dice (two) labeled standard 1-6; two methods of calculating p(7) get different p?
Scenario 1]
The dice are rolled out of your sight and you are then asked the p(7), before you are allowed to look at the results.
Calculate p(7) by looking at table of 36 possibilities and counting the number of sum cells totals that equal 7, there are six of them, so
p(7) = 6/36 = 1/6
Scenario 2]
Same as in 1 except before you're requested for your calculation of p(7) you are informed that one of the faces shows a six.
You calculate p(7) by looking at the table of 36 possibilities and counting the number of possibilities that include six (the cells comprised of row 6 and column 6) so you count 11 of these cells whose row or column value is 6, and notice that 2 of them indicate 7 as their cell sums so
p(7) = 2/11 > 1/6
Sorry to come in late. The question is ambiguous and has no well-defined answer unless you describe how the information about the faces has been obtained. This is the same as the "second child" problem.
To show how the question has no unique answer, consider these three example cases:
1) The dice are thrown. Someone looks at the first die and tells you what it reads. In this case, you are told "one of the faces shows an ##n##", where ##n## is any number between one and six with equal probability.
In this scenario, the probability that the total is ##7## remains ##1/6##.
2) The dice are thrown. Someone looks at both dice and if there is a six they tell you. In this case, you are told "one of the faces shows a ##6##" with probability ##11/36##. And, you are presumably told (or can infer) that neither die shows a ##6## with probability ##25/36##.
In this scenario, the probability that the total is ##7## is slightly changed (as described and simulated above).
3) The dice are thrown. A passer-by is brought in off the street and asked to look at the dice and say something. They say: "one of the faces shows a ##6##".
In this scenario, you cannot compute a well-defined probability without making further assumptions about human behaviour and, in particular: if the dice show ##2## and ##6##, say, how likely it is that the person will choose the ##2## or the ##6##? The natural assumption is perhaps scenario 1: that the choice is equally likely. But, who knows, people in general may have a strong bias towards seeing the number six.
