Diff Eq: Equilibrium Solution sketching?
The discussion centers on finding equilibrium solutions for the differential equation dy/dt = r(1 - y/K)y. The equilibrium points are identified as y = 0 and y = K, with the vertex of the corresponding parabola at (K/2, rK/4). Participants discuss the relationship between the vertex and the intercepts, noting that the vertex lies midway between the intercepts. For a different equation, dy/dt = y(y-1)(y-2), the conversation shifts to finding vertices, with a consensus that calculus is necessary for determining local maxima or minima. Overall, the thread emphasizes the connection between algebraic techniques and calculus in analyzing differential equations.
cdotter
\frac{dy}{dt}=r(1-\frac{y}{K})y
0=r(1-\frac{y}{K})y
y=0 and K.
Plotting dy/dt vs y, the intercepts would then be (0,0) and (0,K).
The book says "the vertex of the parabola is (K/2, rK/4)." Is this something from algebra that I'm forgetting? How do I know/find this?
If you plot the equation dy/dt = r(1 - y/K)y, with dy/dt considered to be a function of y, the graph is a parbola that opens downward. The vertex will be on a vertical line midway between the two y intercepts, namely at y = K/2.
This is the same stuff you learned a while back when you were studying the graphs of parabolas.
What about something like dy/dt = y(y-1)(y-2). I can easily find the points as y=0, 1, and 2. How do I find the vertices? Is there an easy way with algebra or do I just use maximum/minimum from calculus I?
I don't believe there are any algebraic techniques to find the local max or min - you'll need to use calculus.
Thank you Mark44. [URL]http://smiliesftw.com/x/bowdown.gif[/URL]
cdotter said:
Thank you Mark44. [PLAIN]http://smiliesftw.com/x/bowdown.gif[/QUOTE]
That's a really cool smily!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
