Diff eq problem appears simple but is deadly
  • Thread starter Thread starter ngm01
    Diff eq
The discussion revolves around solving a system of first-order differential equations, specifically dx/dt + y = 0 and dy/dt + x = 0, with given initial conditions. The initial approach incorrectly treats the equations as leading to a second-order problem, which complicates the solution. Participants clarify that after solving for y, the corresponding x can be derived directly from the relationship x = -dy/dt, rather than solving a second equation for x. The confusion arises from treating the constants in the solutions for x and y as the same, which leads to contradictory initial conditions. Ultimately, the correct method involves differentiating y to find x and applying the initial conditions to solve for the constants.
ngm01
1. Given i. dx/dt + y = 0; x(0) = 1 : ii. dy/dt + x = 0; y(0) = 0 Solve for the solns of x and y
Although these are first order dif eq's I worked them as leading to a second order undetermined coefficients problem
First I wrote them as
i. x' + y = 0 and ii. y' + x = 0
Eqn. ii leads to y' = -x and this to y'' = -x' => -y" = x' substitute back in i. for -y" + y = 0
=> -y" + 0y' + y = 0 now to solve i in it's new form of a 2nd order eqn.
I began by writing as y" -0y'-y=0 and if std form is y''+ay'+by then a=0, b=-1 and a^2 = 0 4b = -4 => a^2 >4b and soln is form of x=C1e^-r1x + C2e^r2x the values for r1 and r2 are calculated from y" + 0y' + y = 0 or r^2 - 1 =0 so r = +/- 1. the soln then becomes x = C1e^x + C2e^-x. Now applying initial value conditions x(0) = 1 => 1 = C1 + C2
I then complete the other half of the problem similarly and end with 0 = C1 + C2
and I'm stuck. Can someone please point out where I'm going wrong?
thanks
You're on the right track but the clump of stuff above is kind of a mess. You're solving y'' - y = 0, so the solution would be y = c1et + c2e-t.
x and y are dependent variables and t is the independent variable.
Edit: Misread the initial condition for y.
Use your initial condition y(0) = 0 to get an equation involving c1 and c2.
After doing that, solve for x, which you show as being equal to -y'. When you get x, use the initial condition x(0) = 1 to get another equation involving c1 and c2.
thanks
My first reaction to this part
"the soln then becomes x = C1e^x + C2e^-x. Now applying initial value conditions x(0) = 1 => 1 = C1 + C2"
is that you were solving from y, but switched to x in the end. Also your independent variable should be t (since the differential is dy/dt). It looked good up to here. You should have
y=C1e^t + C2e^-t , with y(0)=0
Hi sorry for the text jumble...I've managed to pdf and attach my working. Can ayone figure out where I'm going wrong?. Thanks
You have correctly determined that y= C_1e^t+ C_2e^{-t}. From the initial condition, y(0)= C_1+ C_2= 0. You then go back and solve the corresponding differential equation for x and get the same thing, x= C_1e^t+ C_2e^{-t}, for which the initial condition gives C_1+ C_2= 1 and, obviously, those cannot both be true. The problem is that you have no reason to think that the "C_1" and "C_2" constants in the two different solution are the same! But if you write y= C_1e^t+ C_2e^{-t} and x= D_1e^t+ D_2e^{-t} you have four unknown constants and only two conditions to determine them!
Answer: once you have y= C_1e^{t}+ C_2e^{-t}, do not solve another differential equation for x. Instead use the second equation, dy/dt+ x= 0 to find x= -dy/dt= C_1e^{t}- C_2e^t.
Now you have y(0)= C_1+ C_2= 0 and x(0)= C_1- C_2= 1 to solve for C_1 and C_2.
You have y = c1et + c2e-t, and with the initial condition, you get 0 = c1 + c2.
Since y' = - x or equivalently, x = -y', differentiate the equation you have for y and take its negative to get your equation for x. Substitute in your initial condition x(0) = 1 to get a second equation for the constants c1 and c2.
Thanks for the responses...as a follow up to HallsofIvy - the crux of the solution was deciding how to proceed after solving the first diff eq. - I'm still not clear on what led you to determine that solving the second diff eq for x was not the right way to proceed. Would you have made the same decision w/o knowing that the solution of the dx/dt eqn led to a impossible answer?. In other words would you have to work the problem to a dead end before realizing that another avenue was needed?. Cheers
The primary reason for not solving the second differential equation is that it's unnecessary, and trying to do so will create more work/problems. The purpose of doing so would be to find "x=something", but in the problem statement you are given x=-dy/dt. You already know y, so (in general) differentiating it isn't much work.
Aha!... I never thought to look at it in that context... just saw the eqn. and started solving "a mile a minute"...thanks for your insight!... Cheers
9K
