Difference between diffeomorphism and homeomorphism
69 replies · 16K views
Silviu
Hello! I just started reading something on differential geometry and I am not sure I understand the Difference between diffeomorphism and homeomorphism. I understand that the homeomorphism means deforming the topological spaces from one to another into a continuous and bijective way (like a sphere into a cube). As far as I understand diffeomorphism means the same thing, but instead of going directly from a space to the other, you go through ##R^n## before. I can understand that mathematically diffeomorphism is a stronger requirement, but I am not sure I can visualize the difference. Can someone explain this to me? Thank you!
Both are bijective. Homeomorphisms (and their inverses) are continuous, diffeomorphisms (and their inverses) are continuously differentiable, which implies continuity of themselves and their derivatives, i.e. diffeomorph implies homeomorph.
So the difference is the same as with ##\{(x,|x|)\,\vert \,x \in \mathbb{R})\}## and ##\{(x,x^2)\,\vert \,x \in \mathbb{R})\}## at ##x=0##. With homeomorphisms you can "smoothen" sharp edges, with diffeomorphism you can not. E.g. let's consider the everywhere favorable example of a mug and a torus: they are homeomorph but not diffeomorph, because the handle of the mug (normally) isn't clued differentiable. Or to be on the save side: a cube and a sphere are homeomorphic nut not diffeomorphic.
One may also shortly say:
Homeomorphisms are the bijective mappings in the category of topological spaces, whereas diffeomorphisms are the bijective mappings in the category of differentiable manifolds.
This also illustrates the difference: differentiable manifolds are also topological spaces, but not vice versa.
So the difference is the same as with ##\{(x,|x|)\,\vert \,x \in \mathbb{R})\}## and ##\{(x,x^2)\,\vert \,x \in \mathbb{R})\}## at ##x=0##. With homeomorphisms you can "smoothen" sharp edges, with diffeomorphism you can not. E.g. let's consider the everywhere favorable example of a mug and a torus: they are homeomorph bur not diffeomorph, because the handle of the mug (normally) isn't clued differentiable. Or to be on the save side: a cube and a sphere are homeomorphic nut not diffeomorphic.
Thank you for your reply. It makes sense, however I read that diffeomorphically inequivalent homeomorphisms arise only for dim 4 or higher. So, based on this, shouldn't the sphere and the cube (which are 2D objects inside a 3D space) be diffeomorphic (as they are homeomorphic already)?
Silviu said:
Thank you for your reply. It makes sense, however I read ...
It's hard to tell what you have read.
... that diffeomorphically inequivalent homeomorphisms arise only for dim 4 or higher.
Here's what Wikipedia says about it:
For differentiable (smooth) manifolds in dimension less than 4, homeomorphism always implies diffeomorphism: two differentiable (smooth) manifolds of the dimension less than or equal to 3, which are homeomorphic, are also diffeomorphic. That is, if there is a homeomorphism, then there is also a diffeomorphism. This does not mean that any homeomorphism would be a diffeomorphism.
My examples with the absolute value function or the cube are of lower dimension, too. How do you calculate ##\left.\frac{d}{dx}\right|_{x=0}|x|\,?## Furthermore, we can have topological spaces (and with them homeomorphisms) which do not carry a differentiable structure at all, e.g. finite spaces. The crucial point is, that these are not differentiable manifolds, which is a strong additional requirement. And the above is only a statement about existence, not about inclusion, implication or equality.
An example, that not the same functions are meant by "existence" would be: A circle and an ellipse are both differential manifolds and homeomorphic as well as diffeomorphic. We can transform the circle homeomorphis into and onto a square and this square to the ellipse. Those functions will be a homeomorphism, but no diffeomorphism. Nevertheless, there is also a diffeomorphism which transforms the circle into and onto the ellipse - without having edges in between.
Isn't that just the embedding of the cube in ##\mathbb R^3## that is not smooth? That the embedding in ##\mathbb R^3## is not smooth does not mean that there cannot be a differentiable structure. You could define a differentiable structure on the cube just by projecting it onto the sphere. This structure would (naturally) be diffeomorphic to the sphere (it has to be, there is only one differentiable structure on the 2-sphere).
Some topological manifolds can have more than one differentiable structure. This means that as smooth manifolds, they are homeomorphic but not diffeomorphic.
Interesting question. It boils down to the question: What is an edge on a manifold? I would define it as continuous but not differentiable point, i.e. the (general) curves through it. However, I'm not sure if it is a reasonable definition this way. But to have a counterexample, we can live with embeddings, aka subspaces of ##\mathbb{R}^n##. Manifold doesn't require not to be embedded carrying the induced topology. And as a counterexample, it has not to be true for all differentiable structures.
The point is that if you can put a differentiable structure on a topological manifold, you should be able to put one on all manifolds that are homeomorphic to it by using the homeomorphism.
You later have the fact lavinia mentions - a topological manifold might allow several distinct (under diffeomorphisms) differentiable structures. The 2-sphere only admits one though.
This means the topological structure, which is used to define the homeomorphism, is already given by the differentiable structure. This is quite a strong requirement which restricts possible topologies. Is this why topologies which don't have this property in dimensions 4 and higher are called exotic?
We have had discussions about the subject ealier (2014): https://www.physicsforums.com/threads/diffeomorphism-vs-homeomorphism.731632/
which is probably on A level, but Google found me more on PF, which I haven't checked. Would be interesting to find out about the difference between this Google search list and our own.
I've found these two articles which also might be of interest in this context (the second for whom is interested in mathematical history):
https://www3.nd.edu/~lnicolae/FYsem2003.pdf
http://www.mathunion.org/ICM/ICM1958/Main/icm1958.0433.0440.ocr.pdf
I think "exotic" refers to a non-standard differentiable structure on a given topological manifold.
An exotic 7 sphere is a topological 7 sphere with a differentiable structure that is not diffeomorphic to the standard 7 sphere in Euclidean space. Milnor's original paper was called "On Manifolds Homeomorphic to the 7 Sphere."
I don't think any exotic 7 sphere can be embedded smoothly in ##R^8##.
A standard, kind of simple example is that of ## (\mathbb R, Id.)## and ##(\mathbb R, x^3)## , which are homeomorphic but not diffeomorphic, although ##\mathbb R## has just one differential structure. Meaning the coordinate maps are, resp. the Id and ##x^3##; this last is not differentiable at ##x=0##.EDIT: in 4-manifolds, the existence of differentiable structures is given by the mid-homology intersection form. EDIT2: I wrote this quickly last night; as @vanhees71 points out , the issue here is with the inverse, which is not differentiable at ##x=0##.
Hm, the polynom ##f(x)=x^3## is differentiable everywhere. It's the inverse function ##g(x)=x^{1/3}## that is not differentiable at ##x=0##. So indeed, ##f## is not a diffeomorphism at ##x=0##.
Let ##F: (\mathbb R, Id.) → (\mathbb R, x^3)## by ##F(x) = x^{1/3}##.
Isn't ##F## a diffeomorphism?
I thought the derivative had to be continuous to establish a diffeomorphism.
##f(x)=x^3## is differentiable on ##\mathbb{R}## and invertible, but the inverse is not differentiable. The inverse is ##g(x)=f^{-1}(x)=x^{1/3}##, since ##f'(0)=0## the inverse ##g## is not differentiable in ##x=0## and thus ##f## is not a diffeomorphism.
Maybe that is required in some cases, even ## C^{\infty} ## , but the issue is, as Vanhees71 pointed out, that ## f: \mathbb R \rightarrow \mathbb R : f(x)=x^3## is differentiable, but its inverse is not, at ##x=0##.
Still, an interesting question, IMHO, is , which properties are preserved by diffeomorphisms that are not preserved by homeos., or, which properties do pairs of diffeomorphic spaces share that homeomorphic ones do not? Other than the collection of differentiable functions, I can't tell. Maybe DeRham Cohomology ( Since forms are pulled back by F )?
... which is the same as saying it is not continuous at ##0##. It isn't defined, so whether you say not differentibale or not continuous doesn't make the difference here.
What is wrong with this argument?
Given a function ##F:M→N## between two smooth manifolds then ##F## is smooth if for any coordinate chart ##Φ: U⊂N→\mathbb R##, ##Φ \circ F## is smooth on ##M##.
##(\mathbb R, x^3)## has only one chart ##Φ(x) = x^3## and ##Φ \circ F = Id_{(\mathbb R, Id.)}## is smooth. Therefore ##F## is a smooth bijection.
##F^{-1}:(\mathbb R, x^3)→(\mathbb R, Id.)## is ##F^{-1}(x) = x^3##. The only chart on ##(\mathbb R, Id.)## is ##Φ(x) = x## so ##Φ \circ F^{-1} = x^3## and this is smooth on ##(\mathbb R, x^3)##. So ##F^{-1}## is a smooth bijection.
But the derivative being continuous is stronger than the inverse being differentiable. Yes, they do agree in this case, but not always.
Given a function ##F:M→N## between two smooth manifolds then ##F## is smooth if for any coordinate chart ##Φ: U⊂N→R##, ##Φ \circ F## is smooth on ##M##.
##(\mathbb R, x^3)## has only one chart ##Φ(x) = x^3## and ##Φ \circ F = Id_{(\mathbb R, Id.)## is smooth. Therefore ##F## is a smooth bijection.
##F^{-1}:(\mathbb R, x^3)→(\mathbb R, Id.)## is ##F^{-1}(x) = x^3##. The only chart on ##(\mathbb R, Id.)## is ##Φ(x) = x## so ##Φ \circ F^{-1} = x^3## sand this is smooth on ##(\mathbb R, x^3)##. So ##f^{-1}## is a smooth bijection.
I think you're showing that the differential structures are equivalent (by definition of their equivalence), but it is still the case that ## f^{-1}(x)=x^{1/3} ## is not differentiable at ##0 ##.
Didn't I show that the map is a diffeomorphism?
But the original map is from ## ( \mathbb R,Id ) ## to itself., and your argument does not hold for this case. I think so.
WWGD said:
But the original map is from ## ( \mathbb R,Id ) ## ) to itself.
No it is from ## ( \mathbb R,Id ) ## to ## ( \mathbb R,x^3) ##
But my argument is that my map ##f(x)=x^3## from ##(\mathbb R, Id) ## to itself is a homeo but not a diffeo. As you showed, ##f(x)=x^3## is a diffeo. between ##(\mathbb R, Id) , (\mathbb R, x^{-1/3})## , but that is a different argument.
Don't we have to require the same condition on ##F^{-1}:N→M## and a chart ##\Psi: V⊂M→\mathbb R\,##?
Yes.
lavinia said:
Yes.
I think you are right. The process of a pointwise deformation from ##\{x\,\vert \,x \in \mathbb{R}\}## to ##\{x^3\,\vert \,x \in \mathbb{R}\}## is smooth in both directions: ##0## is a fix point and everything around it is smooth. We do not need ##x \mapsto \frac{1}{3}x^{-\frac{2}{3}}## as we do not convert the function, but only the parametrizations between the two functions.
I guess if we simply would have drawn a circle (to be ##\mathbb{R}##) and some kind of smooth loop (cluing the ends of ##(x,x^3)##) and haven't mentioned the function, nobody would have asked whether they are diffeomorph.
Here is something strange.
Two coordinate charts ##φ:U →\mathbb {R^{n}}## and ##ψ:V → \mathbb {R^{n}}## are "compatible" if both ##φ \circ ψ^{-1} ## and ##ψ \circ φ^{-1} ## are smooth functions on the inverse images of ##U∩V##.
For the differentiable manifold ##( \mathbb R,x^3)## all charts must be compatible with ##ψ(x) = x^3##. So ##φ(x^{1/3}) ## must be a smooth function on any open set ##φ^{-1}(U)##. So in particular it seems that the identity function ##φ(x) = x## (considered as a coordinate map) is not smooth on ##( \mathbb R,x^3)##.
For the differentiable manifold ##( \mathbb R,x^3)## all charts must be compatible with ##ψ(x) = x^3##. So ##φ(x^{1/3}) ## must be a smooth function on any open set ##U##. So in particular it seems that the identity function ##φ(x) = x## (considered as a coordinate map) is not smooth on ##( \mathbb R,x^3)##.
This time I looked up definitions to contain my confusions. Say we have the two smooth manifolds ##M=\{x^3\}## and ##N=\mathbb{R}##. Now here's the first trap. Do you consider the manifold ##N## or the Euclidean space ##\mathbb{R}## which provides the atlas for ##M##, when you say compatible with ##ψ(x) = x^3##, i.e. do we consider ##\psi : N \longrightarrow M## or ##\psi## as an inverse of a chart of ##M\,##? Do you mean the compatibility of two charts ##\chi_\alpha \; , \;\psi^{-1}## of ##M##, or what does compatible mean in case ##\psi## is considered a map between manifolds?
I don't see, why we cannot simply take ##U_\alpha = (a^3,b^3)## and ##\chi_\alpha (p) = p ## as charts of ##M## and why the identity function ##\varphi : M \longrightarrow M## isn't simply ##\varphi(p)=p \,##, because we do not need to switch over to roots in this case, except we consider mappings between manifolds, in which case the question might be, if the especially given ##\psi : N \longrightarrow M## is smooth, invertible and whether the inverse is smooth, too.
Sorry for my confusion caused by the triple role of ##\mathbb{R}##: twice an atlas and once a manifold.
