Undergrad Difference between direct sum and direct product
Direct sum and direct product are distinct concepts in mathematics, particularly in group theory and linear algebra. The direct sum combines vector spaces or modules, resulting in a structure that emphasizes additive properties, while the direct product focuses on multiplicative structures, often represented as Cartesian products. For example, a direct sum of a 2x2 matrix and a 3x3 matrix yields a 5x5 matrix, whereas their direct product results in a 6x6 matrix. The terminology can be misleading, especially when referring to tensor products, which are sometimes labeled as direct products. Context usually clarifies their usage, but the distinction is important for understanding their applications in quantum mechanics and other fields.
Silviu
Hello! I am reading something about applications of group theory in quantum mechanics and I got confused about the difference between direct sum and direct product. In many places I found that they mean the same thing. However, the ways I found them defined in the book I read from, seem to be different, even if they use the same mathematical symbol to represent the 2 of them. I attached the 2 ways they are defined in the book. So according to these definitions, if I understand it right, If A is 2x2 and B is 3x3, the direct sum will be 5x5 and the direct product will be 6x6, which are obviously not the same thing. So, can anyone explain this to me please? Thank you!
What is called a direct product here is misleading. It should better be named what it is: a tensor product.
A direct product and a direct sum are really often the same and are used to emphasize on the underlying structure. With additive structures like vector spaces, rings, algebras and here mappings one usually uses direct sum. On multiplicative structures like groups one may use direct product. The direct product can also be the cartesian product of sets. E.g.: Addition in a vector space ##V## is a function from the direct product ##V \times V## - here the cartesian product of pairs - onto ##V##. And the direct sum ##V \oplus V## is the set of all pairs added: ##V \oplus V = \{ u + v \, | \, u,v \in V\}##
Normally it is clear by the context it is used in.
However, the term direct product for a tensor product - only to distinguish between the direct sum of mappings and the tensor product - is rather unfortunate.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
