Difference between ohmic contact and schottky contact
The discussion focuses on the differences between ohmic contacts and Schottky contacts in the context of fabricating photodiodes, specifically p-n junctions. Ohmic contacts are preferred for their linear current-voltage characteristics, making them ideal for signal transmission. In contrast, Schottky contacts provide rectification, which can enhance sensitivity in photodiodes. Ultimately, the choice between these contacts depends on the specific application requirements, such as the need for signal rectification versus linear conductivity.
  • Understanding of semiconductor physics
  • Familiarity with p-n junctions
  • Knowledge of electrical contact types
  • Experience with photodiode applications
  • Research the fabrication techniques for photodiodes using ohmic contacts
  • Explore the properties and applications of Schottky diodes
  • Study the impact of contact resistance on photodiode performance
  • Investigate materials used for ohmic and Schottky contacts in semiconductor devices
Engineers and researchers involved in semiconductor device fabrication, particularly those focused on photodiode technology and contact engineering.
ralden
Hi guys!, i want to know the advantages/disadvantages of using ohmic contact and schottky contact, because i will fabricate a photodiode (p-n junction) and lot of the articles say that ohmic contact is the best for this kind of device. But schottky contact rectify the signal which is more important if you want to have a high sensitive photodiode so guys, what is the best metal contact for photodiode? thanks in advance!
It depends on one's objective - "Schottky Contacts make good diodes, and can even be used to make a kind of transistor, but for getting signals into and out of a semiconductor device, we generally want a contact that is Ohmic. Ohmic contacts conduct the same for both polarities. (They obey Ohm's Law)."
http://www.cleanroom.byu.edu/ohmic-schottky.phtml
12K
