Difference Quotient Isn't working.
  • Thread starter Thread starter themadhatter1
    Difference quotient
9 replies · 3K views
themadhatter1
Find the derivative of f using the difference quotient and use the derivative of f to determine any points on the graph of f where the tangent line is horizontal.
[tex]f(x)=3x^3-9x[/tex]
[tex]\lim_{\Delta x\rightarrow0}=\frac{3(x+\Delta x)^3-9(x+\Delta x)-3x^3+9x}{\Delta x}[/tex]
[tex]\lim_{\Delta x\rightarrow0}=\frac{3(x^3+3x^2\Delta x+3x\Delta x^2+\Delta x^3)-9x-9\Delta x-3x^3+9x}{\Delta x}[/tex]
[tex]\lim_{\Delta x\rightarrow0}=\frac{3x^3+9x^2\Delta x+9x\Delta x^2+3\Delta x^3-9x-9\Delta x-3x^3+9x}{\Delta x}[/tex]
The '3x3's and '9x's cancel out and you are left with
[tex]\lim_{\Delta x\rightarrow0}=\frac{9x^2\Delta x+9x\Delta x^2+3\Delta x^3-9\Delta x}{\Delta x}[/tex]
Then if you take the limit as delta x approaches 0 you will get
[tex]9x^2+9x-6[/tex] I know the answer is [tex]9x^2-9[/tex] via the rules of differentiation.
What am I doing wrong with this example?
Check the bolded step again.
You can cancel factors of [itex]\Delta x[/itex] from each term in the numerator with the one in the denominator. What are you left with after this cancellation? What is the limit of this expression when [itex]\Delta x \rightarrow 0[/itex]?
Ok, so you would get this after taking the limit.
[tex]=9x^2+9x\Delta x+3\Delta x^2-9[/tex]
what happens to the delta x terms though? Is delta x just such a small number [tex]\epsilon[/tex] that you can say they are practically 0 and anything multiplied by 0 is 0?
No. Please review limits before you go on to derivatives.
Nevermind you would simply factor out a delta x out of the numerator then you have 2 'delta x's that cancel out. Then you take the limit and you get 9x2-9. Otherwise its in indiscriminate form.
I think you mean "indeterminant" form.
I think you meant "indeterminate" form.
HallsOfIvy was being indiscriminate.:smile:
