Different probabilities depending on meaning?
  • Context: Undergrad
  • Thread starter Thread starter homer5439
    Probabilities
The discussion revolves around the interpretation of probabilities in the context of rolling a fair die multiple times, specifically focusing on the probability of rolling consecutive sixes. Participants explore the implications of prior outcomes on future rolls and the distinction between independent and conditional probabilities.
  • Some participants assert that the probability of rolling a six on a fair die is always 1/6, regardless of previous outcomes.
  • Others argue that the probability of rolling five consecutive sixes can be viewed differently depending on whether prior rolls are considered, leading to confusion about conditional versus independent probabilities.
  • A distinction is made between two scenarios: rolling five consecutive sixes (A) and rolling five consecutive sixes given that four sixes have already been rolled (B), with some participants suggesting that the latter is a conditional probability.
  • Some participants challenge the notion that prior outcomes influence future rolls, emphasizing that outcomes of independent events should not affect one another.
  • There is a contention regarding the interpretation of patterns in outcomes and whether they indicate dependence or independence in probability.
Participants do not reach consensus on the interpretation of probabilities in this context. Disagreement persists regarding the nature of conditional probabilities and the influence of prior outcomes on future events.
Participants express varying assumptions about independence and conditionality, leading to different interpretations of the same probability scenarios. Some mention the need for empirical evidence to support claims about independence.
  • #31
Jarle said:
You have grossly misunderstood my posts; of course I haven't said such an absurd thing. I have explicitly defined my variables and assigned them with explicit probabilities which I believe no one here will disagree with. I have no idea what you are talking about.
t is absolutely clear here that A and C are not independent variables. If you have rolled four 6es, then it obviously affect the probability of rolling five 6es at that point, since you only have one more to go. It pains me to even explain that.
Perhaps you can explain what you mean then. The probability of getting five in a row (A) given you have four in a row (C) is 1/6. But it doesn't have to be four in a row. It can any number n. The probability extending the string to n+1 is always going to be 1/6. It's not dependent on the length of C or the probability of a string of that length.
I'm sure I'm ever going to convince you, but I'm responding for the benefit of others that are following this thread.
  • #32
Yes, this event is called A|C, or "A given C", and P(A|C) = 1/6. You are confusing A|C with A.
We are talking about explicit events here, A and C.
  • #33
SW VandeCarr said:
Regardless of your opinion regarding randomness, it is true that the probability of rolling four sixes in a row is [tex](1/6)^{4}[/tex] before the fact. After the fact, it is a given and has a probability of one. If you condition the next roll of the die on a probability of one, it is the same as saying the next roll of the die is independent.
If you say that the probability of a six on the fifth roll is conditional on a probability of [tex]1/6^{4}[/tex], either you do not understand the difference between independent probabilities and conditional probabilities OR you are saying that the fifth roll of the die is not independent. Is that what you're saying? Do you (and other prior and would be posters) understand my question?
"The fifth roll of the die is not independent" - exactly. It depends of my opinion regarding randomness.
  • #34
"As previously mentioned P(C) is not 1"
In less sophisticated language than SW would use (I hope I'm not butchering your argument SW - if so, feel free to slap me about )
If you ask at the start of the rolls "what is the probability of obtaining four sixes in a row?" then [itex]P(C) = (1/6)^4[/itex].
If you have already observed those four sixes in a row, and are starting calculations from that point, you treat [itex]P(C) = 1[/itex] - you know they've occurred. In the first case [itex]A[/itex] refers to this question: "What is the probability that in the first five rolls you obtain five sixes?" This leads to [itex]P(A \mid C) = 1/6[/itex], as we've seen.
In the second case [itex]A[/itex] can be interpreted as "What is the probability that, continuing on, we finish the next roll and have five sixes in a row?" The only way that can happen is for the next roll to be a six, since we've seen four. In this sense, all calculation refers to one roll only, but we still obtain [itex]1/6[/itex] as the answer; in this case, however, [itex]P(A) = 1/6 = P(A \mid C)[/itex] because the setting of the problem is different from our first case.
  • #35
"The fifth roll of the die is not independent" - exactly. It depends of my opinion regarding randomness."
Not an opinion - you would need to put forth a description of how one result could possibly be influenced by previous rolls.
  • #36
Why would you use the same event name? C is an event defined by me which does not assume any prior events, hence your new event could more properly be described as C|C, that is, "C given C", who's probability obviously is 1. Naming this C only adds to the confusion.
Again, define your own events if you want to give them "different meaning", and don't misuse mine. A is a single unambiguously defined event which does not assume any prior events, the event you are talking about could more properly be described as A|C. If you want to change the setting where we want five 6es when we already have four, one will only generate confusion by calling the event of getting the last 6 A.
  • #37
Please reread statdad's last post. He gave two cases. P(A|C)=1/6 and P(A|C)=P(A)=1/6. We can't use your definition of P(A) in the conditional probability because P(A) is independent. It's always 1/6. I asked you to go back and read the wiki article on conditional probability. It clearly states that for independent probabilities such as P(A): P(A|C)=P(A). Your definitions only apply to two strings of length four and length five before any rolls occur in each case.
  • #38
No, please reread my definitions of the events. You are apparently too worked up by your presupposition that A and C are independent events, clearly they are not, which leads you to false conclusions about this trivial problem. It is as simple as this, and can be summed by this: rolling five 6s in five rolls has a probability of 1/6^5 (P(A)). Given that you have rolled four 6s(C), the probability becomes 1/6(P(A|C)). Period.
  • #39
Yes, given that you rolled four sixes, the probability of P(A|C)=1/6 conditioned on the given result that you have rolled four 6's in a row. As a given, P(C) now has a probability of 1 because it has already occurred. You don't assign probabilities (other than 1) to events that have already occurred and the result is known. You only assign probabilities to outcomes that are not known. You can say that the probability of 10 consecutive heads in 1/1024; but once such an event has happened, the probability of a string of 11 heads is now 1/2. But the probability of any single toss being a head is 1/2. That has nothing to do with any particular set of coin tosses. That is, the probability of a head with any single toss of a fair coin is an independent probability.
  • #40
"C, when C is given", or "C given C" reads C|C - not C - as C is defined in the prior sample space. It's problematic not to differentiate notation between events when you are changing your sample space. It has certainly caused the confusion in this thread where no confusion ought occur.
  • #41
It's problematic because you are using simple probabilities but calling them conditional probabilities. The proper sample space is the one I'm using for the conditional probabilities of contingent independent events.
  • #42
It is simple P(AB) != P(A)P(B).
  • #43
There is a 1/7776 probability of rolling ANY specific sequence in 6 tries. 6-6's are one of the 7776 possibilities, it just seems special to some species of animals with a propensity for classifying things.
  • #44
"It is simple P(AB) != P(A)P(B)."
You have simply given a statement of what it means for events to be dependent - you have neither given your explanation for how you see this happening nor how this might apply to the issue under discussion.
You say in #33 "Right: the fifth roll of the die is not independent".
Give an example of two events, [itex]A, B[/itex], where [itex]A[/itex] refers to some specific result of the first four rolls and [itex]B[/itex] refers to a specific result of the fifth roll, but where
[tex] P(A \cap B) \ne P(A)\,P(B)[/tex]
  • #45
Correct me if I wrong, but wouldn't true randomness imply that any conditional property of an event given any history of event (ie P(A | X) where X is any composition of events that occur prior to A) is essentially the same for all X?
Basically it seems that if X does affect the outcome of A, then it seems to imply that there is some order to how A occurs.
If the experiment is done a significant number of times and all conditional probabilities show the above, then through law of large numbers, the real sample probabilities will reflect the population probabilities with greater and greater accuracy.
If conditional probabilities did not end up being the same, it would indicate that there is more of a pattern than one that is truly random.
  • #46
For example, changing the center of gravity of the cube during testing.
  • #47
"For example, changing the center of gravity of the cube during testing."
Nope. Changing a characteristic of the die would result in a new experiment: you would not be justified doing probability calculations from the "old" die to predict results from the "new" one.
  • #48
Sorry, did not catch. Not old not new one, just the die (one die) whose properties you don't know exactly.
  • · Replies 16 ·
  • · Replies 41 ·
