- Messages
- 4,140
- Reaction score
- 1,741
I am trying to understand cosmological expansion and how it is possible to see objects that are receding from us faster than the speed of light. This is explained in words at http://www.mso.anu.edu.au/~charley/p...DavisSciAm.pdf" and I have tried to describe a simple mathematical model to understand how this works, as follows:
Assume the universe is expanding at an arithmetic (rather than a geometric) rate k relative to distance at time t0. By this we mean that, if we denote the distance between points x and x' at time t by d(t,x,x') then, for t1>t0:
Consider points x1 and x2 such that k*d(t0,x1,x2) = b*c where b>1. In other words, at time t0, x2 is receding from x1 at a speed faster than light.
I want to derive a formula for the distance y(t) from x1 of a photon emitted from x2 at time t0 in the direction of x1, as a function of time.
The velocity towards x1 of the photon at time t, when it is y(t) away from x1, is the speed of light c, less the speed of expansion at time t, which is:
where x(t) is the location of the photon at time t. That location is currently y(t) away from x1 which, given our expansion rule must be equal to k * (t-t0) * d(t0,x(t),x1). Hence d(t0,x(t),x1) = y(t)/(1+k*(t-t0)), whence:
We need to solve this ordinary differential equation to get a formula for y(t). The trouble is I never studied ODEs in sufficient depth to be able to solve this.
I could program a numeric solution given numeric values for k and d(t0,x2,x1) but an analytic solution would be much more illuminating.
Can anyone solve the ODE?
Thank you very much for any help!
d(t1,x,x') = (1+k(t1-t0)) d(t0,x,x').Consider points x1 and x2 such that k*d(t0,x1,x2) = b*c where b>1. In other words, at time t0, x2 is receding from x1 at a speed faster than light.
-dy(t)/dt = c – k * d(t0,x(t),x1)where x(t) is the location of the photon at time t. That location is currently y(t) away from x1 which, given our expansion rule must be equal to k * (t-t0) * d(t0,x(t),x1). Hence d(t0,x(t),x1) = y(t)/(1+k*(t-t0)), whence:
-dy(t)/dt = c – k * y(t) / (1+k*(t-t0))We need to solve this ordinary differential equation to get a formula for y(t). The trouble is I never studied ODEs in sufficient depth to be able to solve this.
