Differential Equations - First Order Systems
twiztidmxcn
Solve:
dx / dt = 3*x + y
dy / dt = -y
As for solving this, here is what I've got so far:
Since dy/dt is separable, I found that dy / y = -dt, integrated, and solved explicitly for y:
y = Ce^-t
I then plugged Ce^-t for y in the dx / dt portion of the system and found that:
dx/dt - (3*x) = Ce^-t
Then used Integrating Factor method, found u(t) = e^(-3t), multiplied to both sides and integrated and solved explicitly for x.
x = (-1/3)C + Ce^(3t)
For the second portion of the question, it asks to verify that the solution is correct.
To do that, I plugged in the x and y solutions from part 1, as well as took derivatives of x and y and plugged them in as well.
dy / dt = -y, -Ce^-t = -Ce^-t
However, the problem I am having is that when I plug in for the dx / dt equation, I get down to t = ln1 = 0.
I don't understand if this is wrong or what, as the y solution works but the x one doesn't seem to come to any reasonable conclusion.
Any help in understanding these results, or in finding mistakes would be much appreciated.
-twiztidmxcn
twiztidmxcn said:
Solve:
dx / dt = 3*x + y
dy / dt = -y
y = Ce^-t
so far so good
I don't get this. I get [itex]x(t) = - \frac{1}{4C} e^{-Ct}[/itex].
You have done a mistake either in integrating or in solving for x.
hrm, I've re-done the integration multiple times and keep getting the same thing.
I am integrating this:
(x*e^(-3t))' = C*e^(-4t)
After integrating I get:
x*e^(-3t) = ( -C / [3e^(3t)] ) + C
Divide out the u(t) = e^(-3t) and end up with this:
x = (-C / 3) + C*e^(3t)
I've also done this integration in both Maple and Mathematica and got the same thing as what I got by hand.
So...I'm not sure its the integration or solving for x, I'm baffled.
Sorry, I had made a few mistakes .
I did forget the constant of integration (sorry) and I made typos by putting the C in the denominator instead of the numerator and putting it in the exponential (it's getting too late for me to do simple maths!).
here is my work
[itex]d/dt(x e^{-3t}) = C e^{-4t} \rightarrow x e^{-3t} = -\frac{C}{4} e^{-4t} + K[/itex]
wher I use K for the constant of integration to distinguish it from C. Solving, we get
[itex]x = -\frac{C}{4} e^{-t} + K e^{3t}[/itex]
It's your integration of e^(-4t) which is incorrect.
You may check that my answer satisfies the DE for x(t)
regards
Patrick
Haha, I just caught my error. Ima give it a whirl now with the CORRECT integral, hehe.
Thank you nrged
*edit* - got it, much thanks to you nrged
Thank you nrged
:biggrin:Good! And you are welcome. Sorry for my mistakes.
Best luck!
