Differential Equations - first order
4 replies · 2K views · last reply
FaraDazed
a function has the feature that at any point, the product of its gradient and the x-cordinate is equal to the square root of the y-cordinate multiplied by 5.
Part A: Write out a differential equation that describes the function
Part B: If the curve passes through the point x=7/3, y=2, find the particular solution the differential equation.
n/a
Right, I am extremely new to differential equations so go easy on me.
What I have done is below, I would be very grateful if someone could check my workings please. Thanks :)
p.s. sorry for the many steps, i like to do every little step
Part A:
[itex] \\[/itex]
Part B: First I find the general solution
[tex] \begin{eqnarray}<br /> x (\frac{dy}{dx})&=&5\sqrt{y} \\<br /> x \,\, dy &=& 5\sqrt{y} \,\,dx \\<br /> dy&=&5\sqrt{y}x^{-1}\,\, dx \\<br /> \frac{1}{\sqrt{y}} \,\,dy &=& 5x^{-1} \,\,dx \\<br /> y^{-\frac{1}{2}} \,\,dy &=& 5x^{-1} \,\,dx \\<br /> \frac{1}{5}y^{-\frac{1}{2}} \,\, dy&=&x^{-1} \,\,dx \\<br /> \int\frac{1}{5}y^{-\frac{1}{2}} \,\, dy&=&\int x^{-1} \,\,dx \\<br /> \frac{1}{5}\int y^{-\frac{1}{2}} \,\, dy&=&\int x^{-1} \,\,dx \\<br /> \frac{1}{5}(2y^{\frac{1}{2}})&=&ln|x|+C \\<br /> \frac{2}{5}\sqrt{y}&=&ln|x|+C \\ <br /> \end{eqnarray}[/tex]
Then the particular solution
[tex] C=\frac{2}{5}\sqrt{y}-ln|x| \\<br /> C=\frac{2}{5}\sqrt{2}-ln(\frac{7}{3}=-0.28 \\<br /> \therefore \frac{2}{5}\sqrt{y}=ln|x|-0.28[/tex]
n/a
Part A:
[itex] \\[/itex]
I'd write ## C = \frac 25 \sqrt 2 - \ln\frac 73##. Don't be so quick to plug things into a calculator.
And you need to solve for ##y##. You should find
$$y = \left(\frac 52 \ln \frac{x}{7/3} + \sqrt 2\right)^2.$$ You can see by inspection that ##y## satisfies the initial condition, and you can differentiate it to verify it satisfies the differential equation.
Right ok, thanks. I didn't know I needed to solve for y.
Could I right that logarithm as [itex]\ln \frac{3x}{7}[/itex] or is that not allowed because its in the logarithm ?
Yeah, you can write the log that way. It just wrote it that way because it makes it really obvious that when x=7/3, the log vanishes, so y=2.
Right I see, yeah that makes sense. Thanks :)
