Differential Equations. Reduction of Order. Calc IV.
The discussion focuses on solving the second-order differential equation (x² + 2y')y'' + 2xy' = 0 with initial conditions y(0) = 1 and y'(0) = 0. The method of reduction of order is employed, leading to the substitution y' = p and y'' = p'. The solution process reveals that the equation simplifies to y'^2 + x²y' = 0, resulting in two potential solutions: y' = 0 or y' = -x². The final solution is determined to be y = -x³/3 + 1 after applying the initial conditions.
  • Understanding of second-order differential equations
  • Familiarity with the method of reduction of order
  • Knowledge of initial value problems
  • Basic integration techniques
  • Study the method of reduction of order in greater detail
  • Learn about non-linear differential equations and their solutions
  • Explore the implications of initial conditions in differential equations
  • Practice solving various second-order differential equations
Students and educators in calculus, particularly those focusing on differential equations, as well as mathematicians and engineers dealing with initial value problems.
Gummy Bear
(x2+2y')y''+2xy'=0 with initial conditions of y(0)=1 and y'(0)=0
reduction of order, and exact equations..
let y'=p and y''=p'
Giving: (x2+2p)p'+2xp Let M=2xp and N=(x2+2p)
So, Mp=2x and Nx=2x Therefore, they are exact.
Let fx=2xp
so, f(x,p)=x2p+h(p)
fp=x2=h'(p)
comparing to fp=x2+2p we know h'(p)=2p so, h(p)=p2
so, c=p2+px2
Now, solve for p: using quadratic.
p=(-x2±√(x4+4c))/2
Substitute back for y'=p
y'=(1/2)(-x2±√(x4+4c)
y=?
This is where I'm not sure what to do.
I'm pretty sure I use the initial conditions, do I assume c=0 and take the integral of:
(1/2)(-x2±√(x4))
let y'=p and y''=p'
Let fx=2xp
so, f(x,p)=x2p+h(p)
fp=x2=h'(p)
so, c=p2+px2
Right there you have ##y'^2+x^2y'=c##. If you use ##y'(0)=0## you get ##c=0## so your equation is ##y'^2+x^2y'=y'(y'+x^2)=0##. This tells you that either ##y'=0## or ##y'=-x^2##, both of which are easy to handle.
I'm confused, you're substituting back for p before solving for p? Also, y'(0)≠0 y'(0)=1.
Does that mean my equation should be:
y'2+x2y'=1
And from there solve for y?
I have quoted your original boundary condition. ##p=y'## so I just put it in. It doesn't matter which you call it, but using ##y'## emphasizes that is what it is, and it makes it more natural when using the boundary conditions.
y'2+x2y'=1
No. You get 0 on the right side. It means either ##y'=0## or ##y'=-x^2##. Solve those, apply any boundary conditions and, if you aren't sure, check the solutions work.
Wow. I got it mixed up with the problem out of the book. It's been a long day. You're right..
So all I have to do is:
y=∫0dx=c
y=∫(-x2)dx=(-x3)/3+c
Therefore, y=∫(-x2)dx=(-x3)/3+c is the answer?
Thanks for helping me by the way.
y=∫0dx=c
Use the boundary condition to evaluate c. A second order equation with two initial conditions won't have any arbitrary constants left. And you shouldn't use the same c for both constants.
I should add here that this is a non-linear equation. You get two separate solutions. Nothing says that the sum of those two solutions is also a solution.
Oh, so now I say because y(0)=1 0/3+c2=1 so, c2=1?
Therefore, y=-x3/3+1
What do you mean don't use the same constant? Are you referring to y=∫0dx=c1?
What do I do with the y=∫0dx=c1 anyway?
You apply the boundary condition ##y(0)=1##. Remember you used ##y'(0)=0## to get the two separate solutions. Each of them satisfies ##y(0)=1##. So you have two different solutions to this problem. You should check that they both work.
Ya, I figured that out after asking. But how do I check that both -x3/3+1 and 1 work?
Plug them into the equation and boundary conditions.
  • · Replies 18 ·
