Differential Equations: word problem
4 replies · 11K views
SpiffyEh
When a cake is removed from an oven, its temperature is measured at 300 degrees F, 3 min later its 200, how long will it take for it to cool off to 75? room temp is 70. Assume Newtons law of cooling applies. The rate of cooling is proportional to the difference between the current temp and the ambient temp.
This is what i did:
dx/dt = k(x-70)
dx/dt = k(x-70)
integral 1/(x-70) dx = integral k dt
ln|x-70| = kt+c
after some algebra...
x = C*e^(kt) +70 where C = + or - e^c
at x(o) = 300 so...
300 = C*e^(k*0) +70
which gives me C = 230
x(t) = 230*e^(kt) +70
x(3) = 200
200 =230*e^(k*3) +70
k = 1/3 * ln(13/23)
now that i have an equation i can solve for the time it takes to get to 75
i'll leave k as k since its confusing when put into the equation
75 = 230*e^(kt) +70
i solved and got
t = (3*ln(5/230))/(ln(13/23))
which is approximately 20 minutes
Did i do this right? or did i go wrong somewhere, i just want to make sure I am getting the right idea with these kinds of problems
mathematically i find no mistake
but physically speaking we are formulating an equation for cooling so it is better to write the equation as
dx/dt = -k(x-70)
so that you will get a positive k value in the end of the calculation
because if k value is given as positive in the problem
your steady state result would tend to infinity instead of room temp 70.
x = C*e^(kt) +70
dx/dt = -k(x-70)
x = C*e^(kt) +70
No, it does not- his k is (1/3)ln(13/23), a negative number.
what i wanted to convey is these solutions have a steady state and transient state.
the transient state should tend to zero when time approaches infinty.(for this cooling problem)
x(t) = 230*e^(kt) +70, k<0 should be the solution if you have right idea about this problem
Thank you so much. I didn't think it would make a difference if it was -k or not because i saw an example somewhat similar to this in the book I'm using and it had a positive k. The answer just looked very confusing so i wanted to make sure i doing the question right
