Differential equations, zero state response
The discussion focuses on finding the zero input and zero state response for the differential equation y''(t) + 3y'(t) + 2y(t) = 2 x'(t) - x(t-1), where x(t) = (2e^-t)*u(t). The zero-input response is derived from the homogeneous equation y'' + 3y' + 2y = 0, while the zero-state response involves solving the inhomogeneous equation using the Green's function method. The participant expresses difficulty in determining coefficients for the particular solution and understanding the implications of the step function u(t) and its derivative ζ(t).
  • Understanding of differential equations, specifically second-order linear equations.
  • Familiarity with the concepts of zero input and zero state responses.
  • Knowledge of the Green's function method for solving inhomogeneous differential equations.
  • Basic understanding of the Dirac delta function and step functions in the context of signals and systems.
  • Study the method of undetermined coefficients for finding particular solutions in differential equations.
  • Learn about the application of Green's functions in solving linear differential equations.
  • Explore the properties and applications of the Dirac delta function and step functions in control systems.
  • Review examples of zero input and zero state responses in engineering textbooks or online resources.
Students and professionals in engineering, particularly those studying control systems, signal processing, or applied mathematics, will benefit from this discussion.
serp777
Find the zero input and zero state response for the following system
U(t) is the step function
Y = Yh + Yp
Y = Yzsr + Yzir
I can't find any similar examples online and I am partially thrown off by the u(t) step function, and it's derivative the ζ(t) function.
I have no issues finding the homogenous equation, but the particular part is confusing, specifically finding coefficients. There are no table forms I can find that I can plug back into the differential equation to solve for.
To start finding the particular form, I used the product rule with the step function
right hand side of equation = (-4*e^-t)*u(t) + (4*e^-t)*ζ(t) - 2*e^-(t-1)*u(t)
But I have no idea how to solve for coefficients of this system, basically stuck and I am not able to find the zero state response without finding the particular form.
It's a bit a strange language. The "zero-input response" seems to be the general solution of the homogeneous equation,
y''+3y'+2y=0,
and the "zero-state response" the particular solution of the inhomogeneous equation with the homogeneous initial conditions y(0)=y'(0)=0. I think, this makes the problem much clearer.
The homogeneous problem is solved by the standard ansatz
y(t)=C \exp(\lambda t)
by figuring out the two possible values for \lambda and write down the most general solution in terms of the general superposition of the corresponding two solutions.
The inhomogeneous equation can be solved with help of the Green's function, which seems to be easier to find than to directly solve the problem with the given inhomogeneity.
Finally, note that
u'(t)=\delta(t),
where \delta denotes the Dirac-\delta distribution.
