Differentiating a traveling wavefunction Ψ(x−ut,t)
  • Thread starter Thread starter Spylock
    Wavefunction
Spylock
Hi, I want to check how to show ##\Phi(x,t)## is a solution to TDSE given that ##\Psi(x,t)## is a solution to TDSE. Note that there is no potential.
$$\Phi(x,t)=\Psi(x-ut,t)e^{i(k(x-\omega t)}$$
I am not sure whether I have differentiated correctly
$$\frac{\partial\Psi(x-ut,t)}{\partial t}=-u\frac{\partial\Psi(x-ut,t)}{\partial(x-ut)}+\frac{\partial\Psi(x-ut,t)}{\partial t}$$
and
$$\frac{\partial^2\Psi(x-ut,t)}{\partial x^2}=\frac{\partial^2\Psi(x-ut,t)}{\partial(x-ut)^2}$$
So, we have
$$\frac{\partial\Phi(x,t)}{\partial t}=\frac{\partial\Psi(x-ut,t)}{\partial t}e^{i(kx-\omega t)}-i\omega\Psi(x-ut,t)e^{i(kx-\omega t)}$$
$$\frac{\partial^2\Phi(x,t)}{\partial x^2}=\frac{\partial^2\Psi(x-ut,t)}{\partial x^2}e^{i(kx-\omega t)}-k^2\Psi(x-ut,t)e^{i(kx-\omega t)}+2ik\Psi(x-ut,t)e^{i(kx-\omega t}$$
Also, how do I relate \Psi(x,t) with \Psi(x-ut,t) given that
$$i\hbar\frac{\partial\Psi(x,t)}{\partial t}=-\frac{\hbar^2}{2m}\frac{\partial^2\Psi(x,t)}{\partial x^2}$$
Thank you for advice.
Your equation needs to read: ## \frac{d \Psi(y,t)}{dt}=(\frac{\partial{\Psi(y,t)}}{\partial{y}})_t(\frac{\partial{y}}{\partial{t}})_x+(\frac{\partial{\Psi(y,t)}}{\partial{t}})_y ##, where ## y=x-ut ##.
Also, in the first line, your exponent needs to read ## kx-\omega t ##. (You have a parenthesis in the wrong place). ## u=\frac{\omega}{k} ##.
With the corrections I gave you above, you should be able to finish it up.
Also, be careful when taking ## (\frac{\partial{\Phi(x,t)}}{\partial{t}})_x ##. It basically means taking ## \frac{d}{dt} ## of ## \Psi(x-ut)e^{i(kx-\omega t)} ##, but treating ## x ## as a constant.
