Differentiation Techniques in Calculus
  • Topic:
  • Thread starter Thread starter ardentmed
    Differentiation
5 replies · 3K views
ardentmed
Hey guys,
I have a couple of questions about this problem set I've been working on. I'm doubting some of my answers and I'd appreciate some help.
Question:
For 1a, I just separated the function into single terms with √x as the denominator. This ultimately resulted in: (5/2)x^(3/2) - (9/2)√x + 5/(2x^[3/2])
For 1b, I multiplied the outer variable into the expression in the bracket. This gave me: (4/3) w^(1/3) + (2/(3w^[5/3])) + 2e^w * (w^1/3 + 1/(3w^(2/3))
Does that look right to you guys?
As for 2a, I used the product rule and got 4x^3 *e^(-1/(x^2)) +3xe^(-1/(x^2)) - 2/x^2 * ln (2/x) + 2/(x^2)
Finally, for 2b, I just took the derivative as per usual and obtained:
(-3sin3Ø/cos3Ø) - (sin(ln(3Ø))/Ø)Thanks in advance.
Correct.
Correct.
I got $4x^3e^{-(1/x^2)}+2xe^{-(1/x^2)}-\dfrac{2}{x^2}-\dfrac{2}{x^2}\ln \dfrac{2}{x}$.
You need to show us your work before we can tell you where you went wrong...
anemone said:
Correct.
Correct.
Alright, I re-did the question and got the same answer.
2b is correct, right? I just applied the product rule.
Thanks again.
Thanks again.
For 2b you need to apply the chain rule twice. The Product rule is when you have two expressions multiplied (ie $$\dfrac{d}{dx} \sin(x)\cos(x)$$
Since you are adding you can treat each expression by itself and add the result
$$s(\theta) = \ln(\cos(3\theta)) + \cos(\ln(3\theta))$$
$$s'(\theta) = \dfrac{d}{d\theta}\left(\ln(\cos(3\theta))\right) + \dfrac{d}{d\theta}\left(\cos(\ln(3\theta))\right)$$
So the final answer just: (-3sin3Ø/cos3Ø) - (sin(ln(3Ø))/Ø) After applying the chain rule?
Yeap!(Yes)
