Diffraction pattern to crystal structure
In summary, crystallographers use a diffraction pattern to determine the structure of a crystal. They use a Fourier transformation to calculate the spacing of the planes that make up the crystal, and then use symmetry information to determine how the points within the crystal must be arranged to form the planes.
Stickybees
36
How do crystallographers go from a diffraction pattern to actually determining the structure of the crystal?
http://pwatlas.mt.umist.ac.uk/internetmicroscope/micrographs/microscopy/decr5a-a-big.jpg
This is a fiendishly hard problem to solve. Hence the excitement when Bragg and others managed to crack it and to get crystal structure from X ray scattering photographs.
Start with the simplest example of an interference pattern - the two slits experiment. You can determine the spacing of the slits if you know the wavelength, the separation of the fringes and the distance to the screen (or, in fact, the angle of the resulting maxima and minima at a distance). Now take a grating, of many closely spaced wires - each of which will scatter some light, and shine light of just one wavelength on it. If you get the angle of the incident light just right, a ray will emerge (interfering sum of all the scattered contributions) as if it was reflected from a plane. There is no light scattered in other directions. Knowing the wavelength and the angle will tell you the spacing of the grating.
A crystal consists of many regularly spaced scattering points (in 3D, to make it more complicated). These points lie in planes (like the lines you can draw through a regular array of dots on graph paper) and each of these sets of planes are spaced regularly. The angle at which reflections occur will depend on the spacings and wavelength. Each of the dots on that picture (which is of just one 'perfect' crystal, I think) show the angles for which you get a reflection from a particular set of planes. The photograph will tell you the spacings and angles of all the planes that can be made up by joining scattering points.
'All that you have to do', now, is to decide, from the information of the spacings and angles of the planes, just how the points could be arranged inside the crystal, to form the planes.
It's very much like designing a directional TV transmitting array of many elements when you want a particular radiation pattern. The same sort of calculations are involved and, as Andy R. says, often involves the fact that the angular spacing of the reflections is related to the spatial arrangement of the scatterers by the Fourier relationship but a lot can also be gleaned about the symmetry of the crystal structure by looking at the symmetry of the spot pattern. I remember my Uni course about this and it was quite hard work, involving working in terms of 'k space'.
In general, it seems always to be easier to work from scattering array to radiated pattern than the other way round! But we usually know the radiated pattern and actually want information about the geometry of the scattering points.
Life gets even harder when you are dealing with 'powder' or Organic molecules, rather than one nice big crystal. The pictures become concentric circles and lines, rather than nice clear dots.
Fantastic, thanks. :D
Is that picture taken from a LEED pattern?
Zz.
I'm not too sure, the site it's from just says it's from a TEM.
But thanks for the replies, books and websites don't seem to spend much time on explaining diffraction patterns at my level but it confuses me if I don't at least know where it's coming from.
Also, does anyone know what nD-reciprocal space and nD-direct space mean when talked about quasicrystals here?
http://www.jcrystal.com/steffenweber/qc.html#2. The Concept of Higher Dimensional Space
Reciprocal space describes the lattice spacing in 'atoms per meter' rather than the spacing in metres. So k space is in 1/distance. k space is only (/more?) useful for describing repeating patterns, in the same way that wave number can be used (waves per metre) rather than wavelength.
The crystallography sites are too advanced, probably, to be giving lessons in the basics of diffraction and interference. It's expecting rather a lot too much to get this far all in one jump. :wink:
What is a diffraction pattern?
A diffraction pattern is a collection of spots or lines that are produced when light waves pass through a regular pattern or structure, such as crystals. It is caused by the interference of the light waves as they diffract or bend around the individual atoms within the structure.
How is a diffraction pattern used to determine crystal structure?
A diffraction pattern can be analyzed using mathematical equations to determine the arrangement of atoms within a crystal. This is possible because each crystal structure produces a unique diffraction pattern that can be matched to known patterns in a database.
What is the difference between X-ray diffraction and electron diffraction?
X-ray diffraction involves using x-rays to produce a diffraction pattern, while electron diffraction uses a beam of electrons. X-rays are better suited for studying larger, more complex crystals, while electrons are better for smaller, simpler crystals.
Can a diffraction pattern accurately determine the orientation of crystal planes?
Yes, a diffraction pattern can provide information about the orientation of crystal planes. By analyzing the angles and intensities of the spots or lines, scientists can determine the relative positions of the planes within the crystal.
What are some limitations of using diffraction patterns to determine crystal structure?
Diffraction patterns can be affected by a number of factors, such as impurities in the crystal, crystal defects, and the quality of the crystal sample. Additionally, some structures may produce similar diffraction patterns, making it difficult to accurately determine the crystal structure without additional information.
  • Atomic and Condensed Matter
