Calculating Fall Time: Diffy Q Word Problem with Parachute and Air Resistance
  • Thread starter Thread starter LadyAnn
    Word problem
A person jumps from an airplane at 15,000 feet, falling freely for 35 seconds before opening a parachute, and the discussion focuses on calculating the total fall time considering air resistance. The acceleration during free fall is described as the gravitational force minus the linear air resistance, with different resistance values before and after the parachute opens. Participants suggest using motion equations to determine the distance fallen during free fall and the remaining distance after the parachute opens. There is a debate about the appropriateness of assuming constant acceleration due to varying air resistance as the fall progresses. The conversation emphasizes the need to set up a second-order ordinary differential equation (ODE) to accurately model the motion and solve for the total time to reach the ground.
LadyAnn
A person bails out of an airplane at an a;titude of 15,000 feet, falls freely for 35 seconds, then opens the parachute. How long will it take the person to reach the ground? Assume linear air resistance pV ft/s^2, paking p=.17 without the parachute and p=1.5 with the parachute.
v(0) = 0
The textbook is very vague and unsure how to even approach the set up of this equation please help with detailed explanation. Thank you so very much.
LadyAnn.
Welcome to PF!
Hi LadyAnn ! Welcome to PF! :smile:
The acceleration downwards is g minus pv.
And acceleration = dv/dt.
So solve for v as a function of t. :smile:
Hi LadyAnn
The way I usually tackle these problems is to start with the expression F = m\frac{d^{2}s}{dt^{2}} such that \frac{d^{2}s}{dt^{2}} = F/m
now m doesn't appear in the information you gave so I'd be tempted to assume that F = mg - \hat{p}\frac{ds}{dt} where \hat{p} = mp (ie: I'm assuming p is a lumped constant)
With this you can reduce it to a second order ODE of the form:
\frac{d^{2}s}{dt^{2}}+p\frac{ds}{dt} = g and then solve for s using the fact that at t = 0 you know how fast the person is falling and where the person is.
You can then use the other information to find the required time to fall 15,000ft
@GregA
don't you complicate things?
Mine method:
Treat this as a physics problem. Use those motion formulas
Part 1 - free fall
Part 2 - parachute opens
Find distance covered in part 1: say D1
Distance left = 15,000 - D1
now using acceleration = g - p = a
find final velocity after D1
find time for remaining distance using one of fundamental motion formulas...
use d = vt + 0.5at^2 one...
rootX said:
@GregA
Mine method:
Part 1 - free fall
Hmm...I might be wrong but when you say that a = g-p I infer that the acceleration is constant...surely this is not true though because it depends on how fast that person is falling at any time (air resistance)...and so using the suvat equations would not be correct?
The reason I would reduce it to a second order ODE in terms of position (as opposed to first order in terms of velocity) is that position is surely required to solve for t once the parachute opens?
yep, you seem to be right..
there's "v" after p and I missed it...
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
