Griffy11
- Messages
- 27
- Reaction score
- 0
Hi everyone,
On this page, only questions 4 and 5 I need help for. For question 4, I really have no idea, and there's no real "working" that I can show to really say that I've given it a crack.
For question 5 on that page, I thought along these lines:
In series circuits, voltage changes.
In parallel circuits, current changes.
The first circuit is in series, with the second in parallel.
In the second circuit, I guess the current would be split equally across the two resistors, while in the first it would be the same in each resistor.
Therefore, I believe C is correct - however, I'm probably way off and it really needs clarification in my mind.
For question 8 here, it's a bit like question 4 - I have no idea. Well - I think I do, but I know I'm wrong. Here's my line of thought:
Each "coil" is a solenoid, hence it has a magnetic field.
You determine the direction of the magnetic field using the right hand rule (not sure on even knowing how to use the right hand rule for this)
Then, that gives the direction of the magnetic field, so if two coils have opposite magnetic field directions, they will attract. If they have the same magnetic field direction, they'll repel.
So for example - pair 1.
Magnetic field moves to the right in both coils, thanks to the right hand rule. Therefore they repel? Is this the correct way to go about it?
Another question I had - A sound wave is observed to change its speed, direction of travel and wavelength, but not its frequency. What can we conclude from this?
A) The wave has been reflected
B) The wave has been refracted
C) The wave has been diffracted
D) The wave has been superimposed on another wave
I think the wave has been refracted, but I can't find any solid proof to back my answer up.
2. This question refers to the unlabelled graph below.
Which pair of variables, when plotted against each other, would produce a graph like this?
A) The velocity of a water wave against its wavelength
B) The frequency of a sound wave against its wavelength
C) The amplitude of an electromagnetic wave against its frequency
D) The intensity of a light ray against its wavelength
I'm thinking B again, frequency against wavelength, as the frequency decreases when wavelength increases, but again - I'm not sure, although I'm more certain about this than the other one.
Thanks in advance everyone. :)
