Undergrad Limitations of Dimensional Analysis in Predicting Proportional Relationships
Dimensional analysis can predict relationships between variables, but it has limitations when too many quantities are involved, leading to under-determined systems of equations. For example, adding factors like friction or initial velocity complicates the analysis, making it impossible to derive a unique solution. The fundamental dimensions in mechanics—length, mass, and time—restrict the analysis to three variables. While dimensional analysis can provide insights, it often requires additional physical reasoning to refine results and eliminate unknowns. Ultimately, it serves as a useful tool for checking the consistency of equations rather than providing definitive answers.
physics user1
Our professor introduced us to dimensional analysis and told us that we can use it to predict how some variables are proportional to others, for example:
I have a ball at a certain height and i want to know the time it requires to touch the grond, i can make a guess that it will depend on the height with dimension [L] on g.[L]/[T]^2and on the mass m [M]...
Making calculations: T~ [M]^a [L]^b [L]^c [T]^-2c and i find a=0 b= 1/2 and c= -1/2 that leads to t~h^1/2 * g^(-1/2)
But what if i said in the assumption that the time depends also on the friction force? Or the initial velocity?
Why can't i use dimensional analysis to find a relation between time and these others quantities?
If you add too much quantities in the problem, the system of linear equations from which the exponents are calculated becomes under-determined, which means that you can't find a unique solution.
Likes physics user1
So... How do i solve this problem? If i can't set a system?
Then it can't be solved by simple dimensional analysis. If you have too many quantities ##a,b,c,\dots## that the thing to be calculated depends on, then there are many different products ##a^\alpha b^\beta c^\gamma\dots## that have the correct dimensions, and you can't tell which one of them is correct.
Likes physics user1
So there's a limit where i can go with dimensional analysis? In this case is 3 because 3 are the fundqmentals dimensions in mechanics? L, M and T?
Thanks
Thanks
If you know some kind of a physical reason why the result should depend on a particular power of a given quantity, then you can remove one unknown from the linear system and it may become possible to find a solution by dimensional analysis. The dimensional analysis alone works only for a very limited set of problems.
For instance, the OP's example has a constant factor of ##\sqrt {2}## that cannot be detected by dimensional analysis.
I tend to regard dimensional analysis as a sanity check. If your dimensions don't match, your maths is wrong. If they do match it might be right.
Likes vanhees71
  • · Replies 16 ·
  • · Replies 27 ·
