Dipole pattern for Fine Structure Constant?
The discussion revolves around the dipole pattern detected in relation to the fine structure constant, exploring its orientation relative to Earth and the implications of the measurements. Participants are trying to understand the nature of this dipole pattern, its potential explanations, and the validity of the results.
  • Some participants describe the dipole pattern as indicating a slight variation in the fine structure constant, being lower in one direction and higher in the opposite direction.
  • Others express skepticism about the reliability of this result, suggesting it may not hold up under scrutiny.
  • There are claims that the dipole pattern could be a spurious result due to overfitting of spectral data from heavier elements in quasars.
  • One participant mentions that real systematics in the measurements have been questioned, proposing that the results might be spurious but anticipates better data from future instruments.
  • Several participants seek clarification on the term "dipole pattern," questioning how it relates to measurements and whether it aligns with concepts from other fields, such as radio transmission.
  • There is a discussion about the definition of dipole moments and how they relate to the fine structure constant, including the possibility of higher moments existing if the pattern is more complex.
Participants express differing opinions on the validity of the dipole pattern results, with some believing it may be spurious while others remain uncertain. There is no consensus on the explanations for the observed dipole pattern or its implications.
Participants note limitations in the current understanding, including potential issues with measurement systematics and the need for further data to clarify the situation.
mikenw
Can someone describe for me the dipole pattern that was detected related to the fine structure constant? This thread talks about that pattern some. What I am trying to understand is how that dipole is oriented relative to the observer on Earth? Are we talking about a toroidal shape with a null(s) pointing in some opposite directions of the sky? Or is it something else? I am having trouble visualizing the actual shape of this pattern to the observer on Earth. Thank you! (first time post here too, hello to everyone! :)
Space news on Phys.org
A dipole means that they measured the fine structure constant to be slightly lower in one specific direction, and slightly higher in the opposite direction.
However, this result is highly unlikely to hold up under scrutiny.
Thank you Clanoth for clarifying that!
I am curious why you say "this result is highly unlikely to hold up under scrutiny?" Is there some other more likely explanation for this dipole pattern?
Whether it will hold up or not is a matter of opinion. We shall see. If you want a talk that is relevant watch this:
That it's a spurious result based upon overfitting of the spectra of heavier elements in quasars.
While I don't believe that overfitting is the problem (as that can be tested in simulation), real systematics with the measurements have been called into question. It is in my opinion most likely spurious but we will have better data on it soon. The new ESPRESSO spectrograph will be mounted on the VLT in a couple of years, it's a much more carefully designed instrument than UVES or HIRES in terms of wavelength calibration.
http://arxiv.org/abs/1409.4467
Hey folks,
Can you help me understand exactly what is meant by the term "dipole pattern" in this context? Is it simply the fact that one direction measured + and the opposite direction measured - ? As in this illustration:
This is throwing me for a loop because dipole field strength (at least in ham radio) goes up as you are at 90 degrees to the actual axis of the dipole, not 180. (180 would represent a + to + or - to - ). I normally think of 90 degrees as being the + to - range of field strength for a radio dipole. And yet the Alpha measurements were showing a 180 degree + to - strength change? Any help anyone can offer is much appreciated! (I am probably I am over-complicating it!).
mikenw said:
Hey folks,
I think so. As in, they claimed the fine structure constant was slightly higher in one direction compared to the opposite direction. This is averaged over observations in many different directions.
You get the 90° if you take the magnitude. In radio transmission, you are interested in intensity only, which depends on amplitude squared. Look at the "+-" direction and you see something (if there is a dipole dependence, which is highly questionable), rotate by 90° and you see nothing.
The dipole moment is defined as an integral over the whole solid angle. It is either zero or non-zero, but never a monopole. It has a direction, roughly telling you in which hemisphere something is larger than in the other. The monopole contribution is the average fine-structure constant. Or simply the fine-structure constant if it is constant.
Higher moments can exist in general, if the pattern is more complicated. If there is any variation, you would expect higher moments (quadrupole and so on), but those are harder to measure.
  • · Replies 26 ·
  • · Replies 124 ·
25K
