Dirac Delta Function in an Ordinary Differential Equation
3 replies · 2K views
giveortake
A Spring is attached to a spring is released from rest 1 m below the equilibrium position for the mass–spring system and begins to vibrate. After π/2 sec, the mass is struck by a hammer exerting an impulse on the mass. The system is governed by the symbolic initial value problem
y'' + 9y =−3δ(t−π/2) where y(0)=1 and y'(0)=0. What does the mass do after the hammer strike?
Laplace Transforms:
L(y'') = s[SUP]2[/SUP]L - sy(0) - y'(0)
L(y) = L
1.) Laplace transform of differential equation, where L is the Laplace transform of y:
s2L - sy(0) - y'(0) + 9L = -3e-πs/2
= s2L - s+ 9L = -3e-πs/2
2.) Solve for L
L = (-3e-πs/2 + s) / (s2 + 9)
3.) Solve for y by performing the inverse Laplace on L
Decompose L into 2 parts:
L = -3e-πs/2/(s2 + 9) + s/(s2 + 9)
The inverse Laplace of -3e-πs/2/(s2 + 9) is:
-3⋅H(t-π/2)cos(3(t+π/2))
Where H is the Heaviside function.
The inverse Laplace of s/(s2 + 9) is:
cos(3t)
Thus y = -3⋅H(t-π/2)cos(3(t+π/2)) + cos(3t)
The spring-mass system follows this equation for simple harmonic motion after the hammer strike.
NOTE: The answer according to the back of the textbook is:
y = 0 for t > π/2
I hope you made some typos in the statement of the problem. Maybe you could fix that?
Anyway, the claim that y=0 for t>pi/2 would indicate that the mass sits there at y=0. That is, it seems like the answer in the back of the book is saying the mass comes to rest. You could check that by checking some things.
- Is the mass at y=0 when the hammer hits it? If not, then the y=0 solution is wrong.
- If it is at y=0, then what is the velocity of the mass before it gets hit?
- Is the impulse the correct amount to bring the mass to rest? If not, then the y=0 solution is wrong.
If those things come out correctly to have the mass come to rest, then you don't really need to solve the full differential equation, only the before-getting-hit part.
There are several substitutions you need to make to find the inverse LaPlace transform of this, and I think you have applied one of them incorrectly: ##sin(\omega t) \rightarrow \frac {\omega}{s^2+\omega^2}##.
giveortake said:
Homework Statement: A Spring is attached to a spring is released from rest 1 m below the equilibrium position for the mass–spring system and begins to vibrate. After π/2 sec, the mass is struck by a hammer exerting an impulse on the mass. The system is governed by the symbolic initial value problem
Homework Equations: Laplace Transforms:
L(y'') = s2L - sy(0) - y'(0)
L(y) = L
2.) Solve for L
OK so far
2 mistakes here:
Whence the "3" coefficient? (already pointed out in a previous reply)
And look again at the cosine argument.
If you fix this term you will get zero for ## t \geq \pi/2 ##.
The key operation is ## e^{-bs} F(s) \leftrightarrow f(t-b)H(t-b) ## where ## f(t) \leftrightarrow F(s). ##
I think you used ##e^{-bs} F(s+b) \leftrightarrow f(t)H(t-b) ## which is not the same thing.
