How Does the Dirac Delta Function Apply to Trigonometric Integrals?
The discussion centers on evaluating the integral ##\int_{0}^{\pi}[\delta(cos\theta-1)+ \delta(cos\theta+1)]sin\theta d\theta## using the Dirac Delta Function. The participants clarify that the integral can be transformed through substitution, leading to the evaluation of ##\int_{-1}^{1}[\delta(x-1)+ \delta(x+1)]dx##. The first term evaluates to 1, while the second term's evaluation is debated, with some participants asserting the result must be 2 based on references from Jackson's Electrodynamics.
  • Understanding of the Dirac Delta Function and its properties
  • Familiarity with trigonometric integrals and substitutions
  • Knowledge of limits and their application in integral calculus
  • Basic concepts from classical electrodynamics, particularly Jackson's Electrodynamics
  • Study the properties of the Dirac Delta Function in detail
  • Learn about the implications of limits in integral calculus
  • Review Jackson's Electrodynamics for context on Dirac Delta applications
  • Explore advanced techniques in evaluating improper integrals
Students and professionals in physics, particularly those studying electrodynamics, mathematicians focusing on integral calculus, and anyone interested in the applications of the Dirac Delta Function in trigonometric contexts.
Pual Black
hi
i have to find the result of
i know from Dirac Delta Function that
##\int \delta(x-a)dx=1##
if the region includes x=a and zero otherwise
first i make the substitution
let ##\cos\theta=x##
then ##\sin\theta d\theta=-dx##
at ##\theta=0 \rightarrow x=1##
at ##\theta=\pi \rightarrow x=-1##
##\int_{1}^{-1}[\delta(x-1)+ \delta(x+1)](-dx)##
##\int_{-1}^{1}[\delta(x-1)+ \delta(x+1)](dx)##
##\int_{-1}^{1}\delta(x-1)dx+ \int_{-1}^{1}\delta(x+1)(dx)##
so the first term is equal one but what about the second term. I know that the result must be 2
In ##\delta(x-a) = \delta(x+1)##, what is the value of ##a##?
In L.H.S
X must be equal a. Else dirac delta will be zero.
R.H.S
X=-1
Or a=-1
Maybe I didn't understand your question.
Pual Black said:
a=-1
Correct. So what is the value of the corresponding integral?
Why? I think that the first term is undefined. Something strange is happening at ##x = 1##, so write it as the limit,
$$\int_{-1}^{1} \delta \left( x -1 \right) dx = \lim_{ a \to 1} \int_{-1}^{a} \delta \left( x -1 \right) dx.$$
This two-sided limit, however, does not exist, because
$$\lim_{ a \to 1^-} \int_{-1}^{a} \delta \left( x -1 \right) dx = 0,$$
and
$$\lim_{ a \to 1^+} \int_{-1}^{a} \delta \left( x -1 \right) dx = 1.$$
In the first one-sided limit, ##x = 1## is not in the region of integration, while in the second one-sided limit, ##x = 1## is in the region of integration. Since the two one-sided limits are not equal, the two-sided limit does not exist.
I suppose that you mean the second one-sided limit, i.e., that
$$\int_{-1}^{1} \delta \left( x -1 \right) dx = \lim_{ a \to 1^+} \int_{-1}^{a} \delta \left( x -1 \right) dx.$$
Since a=-1 is in the range of integral. The integral is equal one?
Pual Black said:
hi
How do you know the result must be 2? You are integrating through only half of a ##\delta## function. Some people would say that the result is not defined at all, others would say the final result should be 1 (not the 2 that you give). We could also argue that for ##a > -1## we have ##\int_{-1}^a \delta(x+1) \, dx = 0.15865## or ##= 0.84134## (for both of which there exist perfectly good arguments/justifications). However, I would personally take ##\int_{-1}^a \delta(x+1) \, dx = 1/2##, for more-or-less good reasons.
Ray Vickson said:
How do you know the result must be 2? You are integrating through only half of a ##\delta## function. Some people would say that the result is not defined at all, others would say the final result should be 1 (not the 2 that you give). We could also argue that for ##a > -1## we have ##\int_{-1}^a \delta(x+1) \, dx = 0.15865## or ##= 0.84134## (for both of which there exist perfectly good arguments/justifications). However, I would personally take ##\int_{-1}^a \delta(x+1) \, dx = 1##, for more-or-less good reasons.
The reason why i think the result is 2 because of a problem in Jackson Electrodynamic.
I have now uploaded a pdf file and at page 1 you can see that the integral of dirac delta should be 2.
  • · Replies 31 ·
  • · Replies 19 ·
