Dirac Notation and completeness relation
The discussion revolves around the use of Dirac notation and the completeness relation in quantum mechanics, specifically addressing confusion about manipulating integrals and operators. Participants clarify that when applying the completeness relation, the integral can be pulled outside if the other terms are independent of the variable of integration. There is also a debate about transitioning from an expression involving the eigenvalue p to using the momentum operator, with explanations emphasizing that this is based on algebraic properties rather than operator manipulation. Additionally, the importance of distinguishing between dummy variables in integrals is highlighted to avoid confusion. Overall, the conversation enhances understanding of the completeness relation and operator algebra in quantum mechanics.
0ddbio
I am confused about two minor things right now.
The following illustrates both which I pulled from my QM book:
<x|p_{op}|0>=\int_{-\infty}^{\infty}dp<x|p_{op}|p><p|0>=\int_{-\infty}^{\infty}dp~p<x|p><p|0>
=\int_{-\infty}^{\infty}dp~p\frac{1}{\sqrt{2\pi\hbar}}e^{ipx/\hbar}<p|0>=\frac{\hbar}{i}\frac{d}{dx}\int_{-\infty}^{\infty}dp\frac{1}{\sqrt{2\pi\hbar}}e^{ipx/\hbar}<p|0>
=\frac{\hbar}{i}\frac{d}{dx}\int_{-\infty}^{\infty}dp<x|p><p|0>=\frac{\hbar}{i}\frac{d}{dx}<x|0>
So, the first thing I am confused about is in the middle expression on the top line.
I know they use the completeness relation \int_{-\infty}^{\infty}dp|p><p|=\hat{1} so I guess they just stick that in the middle and I guess it's ok that they pull the integral to the outside because the other terms don't depend on p.
However, what if it was something like: <p|p_{op}|0> when you stick in that completeness relation, you can't pull the integral to the outside... can you?
The second thing that is bothering me is going from the expression on the right (middle line) to the expression on the left (bottom line). They apparently just change p\rightarrow\frac{\hbar}{i}\frac{d}{dx} which I recognize as the momentum operator... BUT, isn't the p the eigenvalue? It first appears on the expression at the right (top line) from p_{op}|p>=p|p> so the p is the eigenvalue... how on Earth do they justify replacing it with the operator expression?
0ddbio said:
However, what if it was something like: <p|p_{op}|0> when you stick in that completeness relation, you can't pull the integral to the outside... can you?[...]
Well, you can't, because \hat{p}\langle p| = p \langle p | and the integral is wrt p.
0ddbio said:
[...] The second thing that is bothering me is going from the expression on the right (middle line) to the expression on the left (bottom line). They apparently just change p\rightarrow\frac{\hbar}{i}\frac{d}{dx} which I recognize as the momentum operator... BUT, isn't the p the eigenvalue? It first appears on the expression at the right (top line) from p_{op}|p>=p|p> so the p is the eigenvalue... how on Earth do they justify replacing it with the operator expression?
There's no operator expression, but a bracket \langle x|p\rangle which is picked up from the complex exponential and the numerical factor in front of it.
Thanks for the response.
I am so sorry, I mentioned the wrong portion of it. I meant to say that about going from the first expression on the middle line to the second. There was no \langle x|p\rangle
I'll just rewrite it here for your convenience. The part I was referring to was this:
\int_{-\infty}^{\infty}dp~p\frac{1}{\sqrt{2\pi\hbar}}e^{ipx/\hbar}\langle p|0\rangle=\frac{\hbar}{i}\frac{d}{dx}\int_{-\infty}^{\infty}dp\frac{1}{\sqrt{2\pi\hbar}}e^{ipx/\hbar}\langle p|0\rangle
and all they did was change the p into it's operator.. but isn't p there just the eigenvalue? So how are they doing that?
thanks.
All they did was use the algebraic fact that p exp(ipx/h) = h/i d/dx exp(ipx/h). No operators involved in that step.
ooh, yes of course!
thank you both very much.
Then the p in \int_{-\infty}^{\infty}dp|p><p|=\hat{1} is a dummy variable, and exists only within the expression on the left hand side. In particular, it is not the p in <p|p_{op}|0>. Therefore, you can still pull the integral outside.
However, you really should use a different dummy variable so that you don't forget which p's are which.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 24 ·
  • · Replies 17 ·
