Dirac notation Schwarz Inequality Proof
The discussion revolves around understanding a proof involving Dirac notation and the Schwarz inequality. The user struggles with the manipulation of terms in the proof, particularly how to derive the expression for <Z|Z> from |Z> and the implications of complex conjugates in inner products. Clarifications are provided regarding the relationship between bras and kets, specifically how the inner product's complex conjugate affects the formulation. The user ultimately gains clarity on the proof's steps and the significance of the complex conjugate in the context of Dirac notation. The conversation highlights the challenges of mastering quantum mechanics notation and the importance of understanding inner product properties.
interdinghy
This isn't really a problem so much as me not being able to see how a proof has proceeded. I've only just today learned about Dirac notation so I'm not too good at actually working with it. The proof in the book is:
|Z> = |V> - <W|V>/|W|^2|W>
<Z|Z> = <V - ( <W|V>/|W|^2 ) W| V - ( <W|V>/|W|^2 ) W> =
<V|V> - ( <W|V><V|W>/|W|^2 ) - ( <W|V>*<W|V>/|W|^2 ) + ( <W|V>*<W|V><W|W>/|W|^4| ) >= 0
This last step has me completely lost, and if someone could explain it I'd really appreciate it. It looks like he's pulled out the <V| and |V> and combined them to get <V|V>, but I don't get where the minus sign comes from, or how he gets any of the rest of the equation, so I'm assuming I'm wrong about where the <V|V> comes from.
I'm deeply sorry about the notation here, I typed this on a phone or I would've used LaTeX.
<Z|Z> >= 0
Mentioned in the first section.
So you know that
<br /> |Z\rangle = |V\rangle - \frac{\langle W|V\rangle}{|W|^2} |W\rangle<br />
So what do you think \langle Z| equals?
kreil said:
So you know that
\langle Z| should just equal <br /> \langle V| - \frac{\langle W|V\rangle}{|W|^2} \langle W|<br />
right? So if I look at \langle Z|Z \rangle, I have to distribute, but I can't see how he's getting the terms he's getting, namely because I don't think I'm too comfortable with Dirac notation yet.
1: \langle V | V \rangle = \langle V | V \rangle obviously,
2: \langle V | - \frac{\langle W|V\rangle}{|W|^2} W \rangle seems like it should equal - \frac{\langle W|V\rangle \langle V|W \rangle}{|W|^2}
3: Probably the most confusing term for me:
\langle - \frac{\langle V|W \rangle}{|W|^2}W|V \rangle
This seems to me like it should just be - \frac{\langle V|W \rangle \langle W|V \rangle}{|W|^2} but this term doesn't appear anywhere in his final formulation really. I mean I guess \langle V|W \rangle is equivalent to his \langle W|V \rangle ^*, but why does he get that conjugate instead of the \langle V|W \rangle that I got?
4: then \langle - \frac{\langle W|V\rangle}{|W|^2} W|- \frac{\langle W|V\rangle}{|W|^2} W \rangle is the first term where I think I'm getting confused. For some reason the term he gets from this has a complex conjugate in it, which I assume means he's moving | - \frac{\langle W | V \rangle}{|W|^2} \rangle to the bra side, which I assume makes the top term a complex conjugate, leaving me with \langle - \frac{\langle W|V\rangle}{|W|^2}\frac{\langle W|V\rangle ^*}{|W|^2} W| W \rangle = \frac{ \langle W|V \rangle \langle W|V \rangle ^* \langle W|W \rangle}{|W|^4}
At the end, my final answer would look like: \langle V | V \rangle - \frac{\langle W|V\rangle \langle V|W \rangle}{|W|^2} - \frac{\langle V|W \rangle \langle W|V \rangle}{|W|^2} + \frac{ \langle W|V \rangle \langle W|V \rangle ^* \langle W|W \rangle}{|W|^4}
This seems like it may at least be equivalent to his formulation based on what I said in 3, but even this took kind of a mental leap for me in part 4 with moving a term over to the bra side. Is that a correct step? If so, why?
Thanks so much for any help. I'm losing sleep over this.
No problem, anyone that gets a science degree loses some sleep over a problem or two, so I know what boat you're in!
Does it help if I say that,
<br /> |Z\rangle = \langle Z|^{\dagger}<br />
<br /> \langle Z| = |Z\rangle ^{\dagger}<br />
and that,
<br /> \langle W |V \rangle ^{\dagger} = \langle W | V \rangle ^* = \langle V|W\rangle ...?<br />
(In other words, the inner product of a bra and a ket is a complex number, and the Hermitian conjugate of a complex number is simply its complex conjugate.)
This all means that,
<br /> \langle Z| = |Z\rangle^{\dagger} = \left( |V\rangle - \frac{\langle W|V\rangle}{|W|^2} |W\rangle \right) ^{\dagger} =\left( \langle V | - \frac{\langle W|V \rangle ^*}{|W|^2} \langle W| \right)<br />
So,
<br /> \langle Z | Z \rangle = \left( \langle V | - \frac{\langle W|V \rangle ^*}{|W|^2} \langle W| \right) \left( |V\rangle - \frac{\langle W|V\rangle}{|W|^2} |W\rangle \right)<br />
See also,
http://en.wikipedia.org/wiki/Bra–ket_notation#Inner_products_and_bras
Yes, that clears it up completely, thank you.
I can now actually see the part in the book where the asterisk denoting that the initial setup involved a complex conjugate has been worn away due to shoddy printing, so I feel a lot better about this whole thing in general now.
Thanks so much!
kreil said:
So you know that
Hmm.. I don't get why the proof starts with that |Z>
Mind to explain it, please? thanks :)
Towards the end they consider, <W|V><V|W> = |<V|W>|, which I cannot understand. Please explain someone.
