Dirac Spinor Algebra: Simplifying Expressions
8 replies · 5K views · last reply
maverick280857
Hi,
In a calculation I am doing, I encounter terms of the form
[tex]\bar{u}^{s_1}(\boldsymbol{\vec{p}})\gamma^{\mu}{v}^{s_2}(\boldsymbol{\vec{q}})[/tex]
where [itex]u[/itex] and [itex]v[/itex] are the electron and positron spinors. Is there any recipe for simplifying this expression, using the spin sums or other identities? I am unable to figure anything out except if I break u and v into components and consider various cases depending on what [itex]s_1[/itex], [itex]s_2[/itex] and [itex]\mu[/itex] are...which is too tedious.
(I have to compute the product of this with [itex]A_{\mu}(x)[/itex])
Suggestions would be greatly appreciated.
Thanks in advance.
PS -- I am not looking at the amplitude squared, so I probably cannot use the trace methods directly..
Okay, so to be more specific, I am interested in simplifying the quantity
[tex]G^{\mu\nu} = Tr\left[u^{s_1}(\boldsymbol{p}_1)\bar{u}^{s_1}(\boldsymbol{p}_1)\gamma^{\mu}v^{s_2}(\boldsymbol{p}_2)\bar{v}^{s_2}(\boldsymbol{p}_2)\gamma^{\nu}\right][/tex]
There is no sum over the spins (so the spin sum identities won't help). Basically I am taking the trace of a 4x4 matrix (for given [itex]\mu[/itex] and [itex]\nu[/itex]).
Any ideas?
Expressions such as [itex]u^{s}(\boldsymbol{p})\bar{u}^{s}(\boldsymbol{p})[/itex] can be simplified by first doing the spin sum, then applying a spin projection matrix that removes the spin you don't want. For example, in Srednicki's conventions, the result is
[tex]u^{s}(\boldsymbol{p})\bar{u}^{s}(\boldsymbol{p})={1\over2}(1-s\gamma_5\rlap{z}\slash)(-\rlap{p}\slash+m)[/tex]
where [itex]z^\mu[/itex] is the spin-quantization axis. For v-type spinors, the result is the same, except +m becomes -m.
This is NOT a sum over spins, this is for a particular value of s (plus or minus one).
Thanks for the replies, Tom and Avodyne. Yes, it's not a spin sum..I think I have to leave it as it is (and wait till some part of the calculations actually requires me to sum over all spins :-P). Or if I want, I can split u and v into their components in some basis, and compute the 4x4 matrix 'by hand'. I don't think there is much point to it, so I'm just leaving it as it is.
Avodyne, your idea assumes that the 3-momenta arguments of both spinors are identical, which is not the case in my problem. In fact, an overall delta function ensures that [itex]\boldsymbol{p}_1 = -\boldsymbol{p}_2[/itex] under a very special case. Otherwise, the 3 momenta could be quite unrelated...which is why I'm thinking now that there may probably be no "identity" that I'm seeking. (It's a bit tempting to assume that there's something to simplify just about everything a novice can possibly encounter in QFT ;-)).
Tom, I'll have a look at the Fierz identity too.
No, it doesn't. You take your expression for [itex]G^{\mu\nu}[/itex], and substitute my expression in two places (with different momenta in each place, and with m->-m where you have v's instead of u's).
Ah, neat. That's because I'm interested in [itex]G^{\mu\nu}[/itex] and not the expression I wrote in my first post. Nice.
