Direct way of solving modulus containing equations
  • Thread starter Thread starter phymatter
    Modulus
A direct method for solving modulus equations, such as |a| + |b| - |c| - |d| = |e| + |f|, is sought to avoid handling multiple cases. While some argue that taking numerous cases is manageable, the discussion highlights the challenge of having multiple unknowns, which complicates finding a quicker solution. The example provided, |2x+3| + |4x-2| - |6x| - |5-7x| = |7x+3| + |9x+2|, illustrates the complexity involved. It is noted that there is no general solution for ambiguous mathematical problems, and solutions depend heavily on the specific details of each case. Identifying symmetry in the problem may help reduce the number of cases needed to solve it.
phymatter
can someone tell me a direct way of solving modulus containing equations other than taking different cases with all terms ,
i mean if we have an equation of the kind |a|+|b|-|c|-|d|=|e|+|f| ,where a,b,c..are some expressions , i cannot take 12 cases! , there would definitely be some technique to solve it directly , please help!
Mathematics news on Phys.org
Oddly enough, there are, in fact, many of us who can count to 12! Taking 12 cases is not all an impossible situation. However, here your real problem is that you have 6 different unknown numbers. What are you trying to solve for and what are the conditions on the other numbers?
i accept that we can count to 12 ,
but here the question is to adopt a quicker approach , say if there were many more variables , then ??
well as i had said a,b,c.. are some expressions in x
as an example say it is :
|2x+3|+|4x-2|-|6x|-|5-7x|=|7x+3|+|9x+2|
(i have just cooked up the values , even i do not know the answer , but it gives the idea of what i am trying to ask)
There is no general solution for an ambiguous problem in math. The solution will always be buried in the exact details of the problem.
Generally speaking, if the problem you are working on exhibits some kind of symmetry, terms might cancel out, and the number of cases will be reduced. Otherwise, there's no guarantees.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
