Directed Energy: Low Intensity Applications
This discussion focuses on the applications of directed energy at low intensities, particularly in the context of removing coatings from surfaces using radiation. Participants explore the feasibility of utilizing specific wavelengths and frequencies to achieve this goal, drawing parallels to medical applications such as laser treatments for tooth whitening and hair removal. The conversation also touches on the military's interest in Free Electron Lasers (FELs) for enhancing directed energy capabilities. Additionally, the discussion highlights the use of electromagnetic waves, including microwaves and ultraviolet (UV) radiation, in various heating applications.
  • Understanding of directed energy concepts
  • Familiarity with electromagnetic waves and their properties
  • Knowledge of laser technology and its applications
  • Basic principles of photolithography and circuit board manufacturing
  • Research Free Electron Lasers (FELs) and their military applications
  • Explore the medical applications of laser technology in detail
  • Study the principles of electromagnetic wave interactions with materials
  • Investigate advanced methods for laser-based removal of coatings from surfaces
Engineers, researchers in materials science, medical professionals utilizing laser treatments, and military technology developers interested in directed energy applications.
RICKYtan
Mostly used for weapons, can sources of directed energy be contained at low intensities? In theory, could it be set to specific wavelengths, frequencies, intensities or whatever to say remove particles of lower cohesiveness from other surfaces or materials?
You mean can we illuminate a surface with a low intensity beam of radiation to remove something like a coating from it?
essentially yeah...but do all forms of radiation illuminate a surface? Unless you just mean to direct a a low intensity of energy
Sorry, by "illuminate" I simply meant that you direct a beam of radiation at a surface, not that you "light it up" like you do with a flashlight or laser. Also, note that energy isn't a substance or an object. You cannot emit energy by itself. It has to be carried by something like a particle or by light.
To answer your question, you can certainly direct radiation onto a surface, but the outcome depends on the surface, the type of radiation, and your overall goal.
The scenario that you are asking about sounds very much like medical used of lasers. For example tooth whitening, hair removal, oder cancer treatment . Illuminating parts of the body while shielding others is the essence of the methods.
I don't understand this question. We already have "low intensity" radiation. Almost everything we have NOW is considered to be low intensity. It is why the military is looking into FELs to generate these "directed energy", to BOOST the intensity of radiation produced.
Zz.
Zz.
what em waves, other than visible light,
heat/evaporate water?
A microwave oven.
All, if they have sufficient power.
Microwaves are convenient for heating food because they get in deep enough to heat the whole food while being easy to produce, but that is an application-specific consideration.
I used to work with 5 eV UV that can burn your skin. Heating and evaporating water is nothing!
You still have not bothered to clarify the issue that I brought up.
Zz.
There are some advanced methods that incorporate laser beams to remove potting from printed circuit boards.
Not to mention the photolithography used to create the chips for the circuit boards in the first place.
Zz.
What does 5 eV UV mean??
UV light where the photons have an energy of 5 eV, corresponding to a wavelength of 250 nm.
  • · Replies 35 ·
  • · Replies 24 ·
