Discontinuity at certain points
The discussion revolves around finding two specific functions, f and g, that are discontinuous at the points {1/n : n a positive integer} and {0} for f, and only at {1/n} for g, while remaining continuous elsewhere. One proposed solution for f is to define it as f(x) = 0 at the discontinuous points and f(x) = x elsewhere, although this only satisfies the conditions for g. Another suggestion is to use f(x) = 1 if x equals 1/n or 0, and 0 otherwise, which aims to create discontinuities. Additionally, a suggestion involves using the floor function, f(x) = [1/x], which introduces jump discontinuities at the specified points. The conversation highlights the challenge of constructing these functions while maintaining continuity in other regions.
rainwyz0706
1.Find a function f : R → R which is discontinuous at the points of the set
{1/n : n a positive integer} ∪ {0} but is continuous everywhere else.
2. Find a function g : R → R which is discontinuous at the points of the set
{1/n : n a positive integer} but is continuous everywhere else.
I'm thinking of making f(x)=0 at points that f is discontinuous and f(x)=x everywhere else. But that only works for 2, not 1, right? Could anyone give me some hints? I'm not sure what the question is asking for. Thanks!
Why not just f(x)= 1 if x= 1/n for some positive integer n or x= 0, 0 otherwise?
only discontinuous..?
try, f(x) =[1/x]...where...[y] is the greatest integer less than or equal to y or as you would call, floor(y)...f(1/n) leads to a jump discontinuity one you can never fix, and hence an implied non-differentiability.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
